Securing a loose screw on the EF 100-400ii
Swervin Mervin
Swervin Mervin Regular Member • Posts: 309
I've got an annoying loose screw on the mount on my 100-400 that works it's way loose every few weeks. I tighten it up and it always comes loose again.
I've read up and people have suggested Loctite Blue
Just wondering if anyone can confirm if this is the right stuff?
https://www.amazon.co.uk/dp/B07BP9JPC9?th=1
 Swervin Mervin's gear list:Swervin Mervin's gear list
Ricoh GR III Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF 85mm F1.8 USM +18 more
BirdShooter7 Veteran Member • Posts: 9,134
Re: Securing a loose screw on the EF 100-400ii
I’ve used the blue loctite to solve this problem with success and was still able to remove the screws later.  I definitely don’t recommend using the red loctite as it’s very difficult to remove the screws if you ever need a repair.  I made that mistake once and had some very uncomfortable time with the heat gun to get the screws out.
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
Wade Oram Junior Member • Posts: 32
More likely to be this one: Loctite Blue 242
Andy01 Veteran Member • Posts: 5,191
Loctite 243 (Blue) is the one you want (which I believe is what the OP linked above).
242 is the "older" version of 243, and is very slightly weaker, and less oil resistant, meaning that the threads have been be cleaned thoroughly for it to work properly. This may, of course, not be a problem on a camera lens, so I am sure that 242 would work as well - if it is still available.
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
Arthur Stanley Jefferson Contributing Member • Posts: 809
Clean the screw, blue thread lock, and use a JIS driver tool of the right size. They are slightly different from Philips
https://www.ifixit.com/products/jis-driver-set
 Arthur Stanley Jefferson's gear list:Arthur Stanley Jefferson's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F4L IS USM +4 more
Steve Balcombe Forum Pro • Posts: 15,582
There's something about the 100-400L II - I've had exactly the same problem with the same lens.
Yes, Loctite 243 as mentioned by another poster. Works perfectly.
I don't recognise that packaging, but search for Loctite 243.
