Great cheap lens :)
Started 2 months ago | User reviews
davel33 Senior Member • Posts: 2,974
Great cheap lens :)
This lens was a nice surprise.  Its very sharp but slow at the long end.  I use it on a R6 which has awesome high ISO performance.  I have never been a fan of the 24-105 range but this with its small size weight its a nice walk about lens.
"Just one more Lens, I promise....."
Dave
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 85mm F2 Macro IS STM +29 more
Canon RF 24-105mm F4.0-7.1 IS STM
Zoom lens • Canon RF
Announced: Feb 12, 2020
davel33's score
4.5
Average community score
4.6
Canon EOS R6 Canon RF 24-105mm F4.0-7.1 IS STM
robgendreau Forum Pro • Posts: 10,917
Re: Great cheap lens :)
I agree.
On a whim (I need help...) I got one refurb'd for a stupid-cheap price, and it's really impressed me. If this is the default kit lens boy, have they gotten better over time. A nice hiking lens, small and light and a useful range.
And for the IR shooters out there no inner IR LED, so it can be used at slow shutter speeds. Yay for that.
Canon's L lenses have always been good, of course. But where they've really stepped it up is in their lower cost, non L options. Great bang for the buck, especially since the slowness of the lens itself isn't as much of an impediment on newer bodies.
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
Steve Balcombe Forum Pro • Posts: 15,571
I agree. I wanted a small, light standard zoom for my R5, something really inexpensive because this is a focal range I don't often need a zoom for, but at the same time can't easily do without. At its usual street price of £400-£450 depending what deals are available it's good value, but I paid £269 grey market so I couldn't really go wrong!
It has one annoying fault, which is the lack of an AF/MF switch, and while the R7 and R10 have a switch on the body, the R5 and R6 don't - and I was surprised to learn that the R6 Mark II also doesn't have this switch. This is a full frame lens, so you'd expect it to be properly supported by a current generation full frame body, not just the two crop bodies.
Wingsfan
Wingsfan Contributing Member • Posts: 678
I purchased mine refurb from canon for $119. I also have the RF L version and at some focal lengths, the cheaper version is equally sharp across-the-board. It may be because mine was refurbished & that it was reset and calibrated properly from the factory.
I'm also using it on the lowly RP, which has fewer megapixels than some of the R series cameras. So I may be less sensitive to design discrepancies then larger mp cameras. I actually use it a lot more than I use the F4 version. It's smaller and lighter, and I don't dare say disposable, but if I'm concerned about where I'm going I will put this on instead of the L version. There are some points where the bokeh is kind of sloppy compared to the f4 L, though.
I'm actually much more impressed with this lens than I am the 50f1.8 ( granted I got that for $79, so I can't complain too much....), which seems to have a slightly smeary rendering.
 Wingsfan's gear list:Wingsfan's gear list
Fujifilm FinePix F31fd Nikon Coolpix 4100 Canon PowerShot S95 Olympus XZ-1 Nikon Coolpix S9100 +24 more
OP davel33 Senior Member • Posts: 2,974
"It has one annoying fault, which is the lack of an AF/MF switch, and while the R7 and R10 have a switch on the body, the R5 and R6 don't"
It sort of does,  You can use the focus/control switch on the lens.  The problem is you lose the control function
Dave
cocoanud
cocoanud Contributing Member • Posts: 699
Thanks for the review on this.
Have a trip coming up shortly where carrying all my gear is not practical. Decided to bring R6, 14-35 f/4, 50 f/1.8, 430EX flash.
However was worried about missing out on 50mm and beyond and didn't really want to include my RF 24-105L.
Found a used copy and looking forward to trying it out. The tests on Optical Limits show that it is not not bad lens at all 40mm and beyond.
I had one for a very short while but replaced it with RF 24-240 so didn't get the chance put it to any meaningful use.
C
 cocoanud's gear list:cocoanud's gear list
Canon EOS R6 Canon EF 100-400mm F4.5-5.6L IS II Canon EF 70-200 F4 II Canon RF 24-105mm F4L IS USM Samyang AF 85mm F1.4 RF +3 more
That enables the focusing ring but it still doesn't give you MF. Half-pressing the shutter initiates AF, which sure you can then fine-tune like a fly-by-wire version of the old 'FTM' - very useful in some situations, but not like MF. The switch on the R7 gives you 'real' MF.
I'm aware of the BBF work-around of course, but I don't use BBF and I especially don't want to enable it for one lens.
I've put 'Focus Mode' on a My Menu page so it's a bit quicker to operate, and when set to MF it works nicely.
I don't want to make too much of this, it's one annoying feature of an otherwise excellent little lens. I fully agree with your 4 1/2 star rating.
an_also
an_also Contributing Member • Posts: 723
How is the corner sharpness at 24mm? I’ve been eying this lens to get for my RP as a cheap light weight travel landscape option.
My wildlife photography:
https://www.instagram.com/anand_iyer/
 an_also's gear list:an_also's gear list
Canon EOS 5D Mark IV Canon EF 400mm F4 DO IS II USM Canon EOS RP Canon Extender EF 1.4x III Canon EF 40mm f/2.8 STM +2 more
drsnoopy Senior Member • Posts: 1,216
Corners are good enough for most purposes at 24mm f5.6 and a little better at f8.  It is not far off the L version for IQ, and I’m mostly shooting at f8 anyway.  My RP and STM lens (880g) are coming skiing next week - I wouldn’t take the R5 + L (1433g)  !!
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Wingsfan
It seems that the image quality on these lenses vary wildly. As I mentioned above my copy is very good pretty much across-the-board. I have no issues shooting wide open at 24, although I'm not usually concerned about my corners at that point. I'm not a pixel peeper but if you are, it might bother you a little bit. If you stop down to about F7.1 you should be pretty good at 24. Let's just say it's not quite as sharp as the L at 24 ( Although my L is better, it isn't particularly good there either).
Again, you're looking at $400, versus $1300. Or in my case, I got it for 119 refurb.
It's a relatively compact system, but if I really need to go small I'll still pack my M43 gear and pro glass.
There are benefits and drawbacks to both systems.
igmcg Junior Member • Posts: 49
SShhhhhh  lol
David Yule Regular Member • Posts: 318
My copy isn't great between 24mm and 26mm, the corners seem to be "stretched" in-camera for jpegs and for RAWs by Lightroom/DPP. There is a theory the image circle doesn't quite cover the sensor around at around 24mm.
Beyond 26mm the lens is good. Sharpness isn't much behind the 24-105F4L.
I do use the lens quite a bit when I want to travel light.
David
an_also
Thanks for the reply. I'm not a really a pixel peeper but it's still nice to have a lens that doesn't look horrible in the corners before you even zoom in to 100%. And this lens sounds like it will be ok in that aspect.
I just ordered this lens in the "Ugly" rated one from KEH for $91. It was cheap enough that if it turns out to be a decent copy, its pretty good for the price.
an_also
Thanks.
an_also
Thanks. The weight savings is the main reason I'm intrigued by this lens.
Not just a theory - if you turn off Profile Corrections in Lightroom you can see the black corners:
That's useful to know - I've never specifically tested that.
thunder storm Forum Pro • Posts: 10,139
I'm wondering how it compares to the Sony FE 28-60mm at f/7.1 or f/8.0. The Canon will perform better at 61-105mm obviously, however, the Sony is definitely more compact in traveling position. The Canon is 395g whereas the Sony is 167g.
The 24-27 of the Canon isn't that much of an advantage to me, as it might be better IQ wise anyway to bring a wide angle for these focal lengths, and I don't like the stretched corners of anything wider than 28mm so much.
An f/2.8  24-70mm can make me wishing for a bit more on the long end, but when the max aperture isn't suitable for portraits 60mm might work as well. I definitely don't need anything over 80mm in a standard zoom.
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
ddixon Regular Member • Posts: 250
I'll skip explaining why, but I've ended up with all three: the 24-70L, 24-105L, and 24-105 STM.
At age 69, I use the 24-70 when I'm not carrying it very far from home or car and want best quality. This for me is 90% of the time, and I always have the RF 70-200 2.8 if I need longer reach.
I use the 24-105L only when I need to travel lighter with one lens (where the extra reach is handy, even with the R5's cropping ability).
The 24-105 STM though, is my casual ultra-light kit when I'm walking and carrying it for long periods. It's very fun to shoot with.
FWIW, speaking for the IQ and sharpness of my copies, I'd rate the 24-70 a 10, the 24-105L a 9, and the STM a 7.5
 ddixon's gear list:ddixon's gear list
Canon EOS R5 Canon EF 85mm F1.8 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 35mm F2 IS USM Canon EF 16-35mm F4L IS USM +3 more
Sittatunga Veteran Member • Posts: 5,406
It doesn't actually need to cover the corners before distortion correction, as correcting that amount of barrel stretches them beyond the image rectangle anyway. The barrel distortion doesn't look particularly bad for that image until you realise that it's just about reversed the catenaries of the electricity cables.
In some ways, heavy barrel distortion or a stereographic projection fisheye looks better than a rectilinear projection wideangle because they preserve the relative angles of 3D objects better away from the centre.  For example,
The photographer on the right and the hikers on the left would have looked very odd had I used a rectilinear lens with this horizontal field of view.
Haha yes true!
This is especially true for wide angle close ups, I've found. I like to use the fisheye zoom at 15 mm for flowers and fungi occasionally.
