Show Your Snaps...January 23, 2023
OP Digirame Forum Pro • Posts: 41,857
Today's Heron - Thanks
Thanks.  It was a good day for "hunting".
Thanks.  I like the background too.  I have different backgrounds when I moved around slightly.
Lazarus1954 New Member • Posts: 3
Pelicans - Isle Blanca, Texas
being extremely self critical.... subjects washed out because i was using wrong metering method (should have used spot, or manual and dialed it in via manual). focus is not what i'd have hoped for, but i suspect that if i'd have used a higher fstop, i might have used depth of field to my advantage. i would have had better luck with fewer focus points also.
That's why we're still learning..
Re: Pelicans - Isle Blanca, Texas
Welcome first time poster.
What's nice about digital photography is that we can learn about our photos and then do it again at low cost. I took pictures of pelicans like that many years ago at Newport Beach, California.
You are correct about using less AF point (like only one) in this particular case. Or sometimes we can use something like 9 center AF points and then make sure that the focus locks on the subject that we are most interested in.
If your exposure is a little off, you can adjust it on the computer.
We hope to see more of your photos...again...welcome.
Ontarian Veteran Member • Posts: 3,859
What's nice about digital photography is that we can learn about our photos and then do it again. I took pictures of pelicans like that many years ago at Newport Beach, California.
You are correct about using only one AF point in this particular case. Or sometimes we can use something like 9 center AF points and then make sure that the focus locks on the subject that we are most interested in.
Yes, with a Canon use single point focus.  A a rule of thumb,  use a shutter speed 500 to 700 per second for stationary birds.  Especially little birds, as they are never still due to their breathing and and being always ready to take flight.  For birds in flight use 1200 or over.
Don
 Ontarian's gear list:Ontarian's gear list
Sony RX10 IV
Dunlin Senior Member • Posts: 2,611
Hola,
Like the others say - a single AF point is usually best.
Keep at it - with effort and practice, you'll soon be delighted with your results.
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
stevet1 Senior Member • Posts: 1,300
Lazarus,
As Dunlin said, Keep at it. It will come.
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
Thanks everyone for your help.  I expect to be over there more during the next months.  Transition from film to digital has been a challenge. but i'm learning
