Canon M6 Mk II - Simulated ISO and "Real" ISO
Spherical New Member • Posts: 7
I read in one Thread here about M6 MK II´s tips that there is something called ISO invariance. Some search later I think I got the point that real ISO invariance is when the Camera has almost no Backend Read Noise. Which is a good thing.
But here in the Forum the term seems to be used to describe when the camera is using simulated ISO. So the Frontend is not able to apply more voltage to the pixels and thus it raises the numbers just like a RAW Editor would do. Thus sometimes decreasing our Dynamic Range. Which is a bad thing.
Is my understanding so far correct?
Then I searched for our beloved M6 Mk II specifically. What are our real ISO values without losing Dynamic Range? Are our in between ISO stops real or also just simulated?
I read this quite deep article (https://photographylife.com/iso-invariance-explainedhttps://photographylife.com/iso-invariance-explained). In it the author linked to this Photons to Photo Graph.
https://photonstophotos.net/Charts/RN_e.htm
I would assume from this Graph that the in between ISO of the M6 II is simulated, because they are lying on a ladder with a full stop in ISO they are close to. Also it seems the last real ISO would be 6400, because after that the ladder effect stops. But I read here in the Forums and elsewhere that the M6 II could have real ISO only up to 400. That would be a major difference and I believe I just interpreted the data incorrect.
Then I found a link to this second Graph.
https://www.photonstophotos.net/Charts/PDR.htm
Here it would indeed show 400 or 800 as the last real ISO. But there is no way to tell what is happenig with the in between ISOs.
I would be very glad if someone with a deep understanding could enlighten me in this matter. Especially about these two questions regarding the M6 II:
Additionally I came across some other real ISO values for other cameras. And people were happy when their camera had only a real ISO of 100, saying somethin like 6400 or 3200 would be bad. I don´t understand this at all.
Shouldn´t be a real ISO of up to 6400 considered to be the best? As in this casse the Frontend has more flexibility to adjust for the incoming light (or lack) instead of pushing it like a editor. And a real ISO of only 100 would mean that everything else is simulated which is bad.
Thank you for this great forum and for any help that will come in this Thread.
Canon EOS M6 II
R2D2 Forum Pro • Posts: 26,528
Re: DxO, the Great Equalizer
To tell the truth, since I’ve started using DxO Photolab (5 and now 6) as my RAW converter I don’t pay much attention at all to the ISO setting, just so long as it’s not getting crazy high.
DxO is the Great Equalizer.
R2
ThrillaMozilla Veteran Member • Posts: 7,665
Re: Canon M6 Mk II - Simulated ISO and "Real" ISO
Don't overthink this.  You can be sure that the Canon engineers know what they are doing, and chances are, they have done a good job on this.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
R2
Definitely. I took thousands of shots in a dimly lit gym on Saturday with my R7 (very similar sensor to the M6II). Quite a few were at ISO 25,600 and they looked great with DXO Deep Prime XD.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
KEG
KEG Veteran Member • Posts: 4,908
R2
DXO also works really well with G7 X II.
Alastair
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
OP Spherical New Member • Posts: 7
Thank you to all for replying. Sorry for not answering for so long, I kind of lost the train of thought in this topic. Still for everyone interested I found the graph which shows where the M6 Mk II is most accurate. And I made some test photos to see if it is really easy to recover the shadows when using such a low ISO as 400.
Maybe this is only really important for night sky shots, but I find it is good to understand the gear in and out. And on that basis of thourough understanding I want to build my routine of shooting without thinking.
For starters here is the link:
https://www.photonstophotos.net/Charts/RN_ADU.htm
As you can see (if you select the M6 II in the right hand list), the noise is lowest at ISO 100, 159 and 318. I don´t understand how they were able to set such uneven ISO numbers, maybe it´s just a mathematical approximation. But I guess that is where the ISO 100 and ISO 400 are the best for this camera comes from.
And now here are photos I took with a tripod and remote shutter. Being careful to quickly change the ISO setting only, so that every shot has similar light. I edited them in DxO to kind of match the exposure, with no noise reduction or anything else. So to see if you get a benefit of underexposing.
The first set of images was correctly exposed for ISO 6400 and then I only stepped down the ISO, leaving the other settings fixed. Maybe it was not good to shoot at 1/4000? The ISO 100 image looks very bad. And to my surprise the ISO6400 looks best in my eyes. But also the ISO 400 looks second best. Again resounding that ISO 400 might be best if in special conditions.
ISO 6400
ISO 1600
ISO 800
ISO 400
ISO 100. It looks comically bad. But I also had to resort to use DxO Smart Lightning here, as the exposure slider only goes to 4. And this was not enough to raise the exposure.
For the next set I did the exposure correct for ISO 1600 and then adjusted. The shutter speed was 1/800 this time. The ISO 100 photo again looks the worst.
ISO 1600
ISO 800
ISO 400
ISO 100
When inspecting these side by side it really seems there is some merit to the claim that ISO 400 is best.
To me ISO 400 looks as good as the initial exposure at ISO 1600. The photos on the right with ISO 800 and 100 look much worse to me.
When comparing the images from the 6400 exposure (of course I left out the bad ISO 100 one), ISO 400 does not look as good. The ISO 6400 photo is clearly superior. ISO 800 looks worse and ISO 1600 and ISO 400 look the same to me.
I still find it very interesing that there is a difference in how our images are taken. Whether the camera amplifies the signal digitally or analog.
Everyone could take from this what they deem necessary. For me, in extreme situations I will remember that ISO 400 is very good. And I turned off the in between ISO steps in my camera, as I can anyway recover that detail in post. Plus, the in between steps may reduce the quality of my photos, which I may could not recover in post.
This is the chart you should be looking at:
https://www.photonstophotos.net/Charts/RN_e.htm#Canon%20EOS%20M6%20Mark%20II_14
On the one you linked, each data point is scaled differently. That means it is multiplied by a different number, and it doesn't correspond directly to any physical unit.
On the chart I linked, the data points all correspond to an physical unit, namely the number of electrons, which in turn corresponds to the number of photons. For example, ISO 100 corresponds to 6 electrons, i.e., 6 photons. That tells you directly what level of subject luminance you can see.
ISpherical wrote:
edited them in DxO to kind of match the exposure....
This is a nice demonstration, but let's keep it clear.
In the first series the exposures were all the same. You determined that before you snapped the shutter. You used DxO to brighten the images to match them for lightness.
If you look at the chart I linked, you should see the biggest difference between ISO 100 and 400, and that actually corresponds very neatly to what you see. The large amount of noise at ISO 100 is dominated by read noise, which is shown in the chart.
In the second series the exposures are 2 1/3 stops higher, so the noise is dominated by shot noise (i.e., photon statistical noise). The read noise is much less visible, and the noise is similar in all images.
The best ISO setting for any exposure is always the highest value that does not result in clipping of any highlights.  Lower values, however, may give results that are nearly as good, and they may give you some needed margin of error.  With the M6 II, ISO 400 is pretty good for all of these photos.  If you could measure accurately, and I'm not sure you can from these images, I think you would find that the ISO values greater than 400 give slightly lower noise levels.  (Although I didn't actually check for clipped highlights, I don't see any.)
ThrillaMozilla wrote:
Spherical wrote:
The best ISO setting for any exposure is always the highest value that does not result in clipping of any [IMPORTANT] highlights. Lower values, however, may give results that are nearly as good, and they may give you some needed margin of error.
+1 The details of this tech talk can certainly seem complicated, but this is it in a nutshell!
When working within the sensor’s ISO Invariant Range, just do the above.
When working below the sensor’s ISO Invariant Range, just do the above.  Easy!
The only time you would have to take any of this sensor-speak into consideration is when your output requirements exceed your end results.  (Just be sure to maximize your end results by shooting RAW and processing with something like DxO   ).
Happy Snapping!
R2
