Wired tethering with the M50 Mk II?
Marie Meyer Contributing Member • Posts: 616
Is anyone shooting tethered (with a cable, not wirelessly) with an M50 Mk II? I'm thinking of getting one, but was surprised to see a note on the TetherTools website saying "This camera may not support tethering or there may be no compatible software at this time. Please check with your camera manufacturer. In this case, the cable below will only work for transferring images."
 Marie Meyer's gear list:Marie Meyer's gear list
Olympus OM-D E-M10 IV Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R
Canon EOS M50 (EOS Kiss M)
Brian Slater Regular Member • Posts: 432
Re: Wired tethering with the M50 Mk II?
If you have a Mac, you can use Kuuvik Capture for wired tethering to the M50ii. Excellent software (for a price).
 Brian Slater's gear list:Brian Slater's gear list
Canon EOS 6D Canon EOS M6 Canon EF 17-40mm f/4.0L USM Canon EF 70-200mm F4L USM Canon EF-S 60mm f/2.8 Macro USM +4 more
Or iPad.
cr3shooter Junior Member • Posts: 42
You should be able to use Canon’s own EOS Utility software – supplied with the camera – to remotely control the M50 Mark II. The link here shows supported cameras and the M50 Mark II is in the list. Some others like M6 (First version) and M5 are shown as not supporting remote shooting.
https://cam.start.canon/en/S003/manual/html/UG-00_Before_0050.html
EUS Utility runs on Windows and Mac, not on Android. Connection to the camera is via USB cable.
