Canon EF tilt shift 24mm versions
AceVentura0212 Regular Member • Posts: 117
Hello, all  I’m looking at buying a used tilt shift lens for architecture and urban landscape photography for my 5DsR  I was thinking of the 24mm as it seems like the sweet spot between the 17mm and the 50mm and have two questions.
1. Is the selection of the 24mm appropriate or should I consider the 17 or 50? Mostly I’ll be shooting individual low rise buildings in the older areas of Miami. These neighborhoods can be a bit compact, but usually are not cramped. I think the 17 would be too wide and the 50 too long.  Thoughts?
2. Assuming I’m right about the 24, which version should I get, the I or the II?  The difference on KEH seems to be nearly a 2x premium for version II. Is this version that much better?
Thanks in advance
A signature? A signature! Oh, man, the pressure ...
 AceVentura0212's gear list:AceVentura0212's gear list
Leica M-Monochrom Leica M-E Typ 220 Canon EOS 5DS R
Canon EOS 5DS R
John Crowe
John Crowe Veteran Member • Posts: 3,476
Re: Canon EF tilt shift 24mm versions
I have had the 17 TS-E for 12 years.  The 24mm sounds more appropriate for your needs and it is easier to compose with.  I just have a love of the ultrawide view lenses.  I have actually forced myself this past year to use it with the EF 1.4x III more often and I am enjoying the 24mm focal length as well.
The 24 TS-E II is significantly better than the original.  The 17 TS-E with 1.4x is better than the original, but not as good as the II.
If you intend to use tilt the II allows more flexibility in combination with shift.
I will also point out that there is also the 15mm f4.5 Shift and 20mm Shift from Laowa.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
randomrubble Regular Member • Posts: 114
The 24 is probably the right FL. However, it can be too wide for exterior shots. I'd recommend adding an EF 1.4x III, in more cases than you'd expect I use an old C/Y fit 35mm f/2.8 PC-Distagon for 'Building Portraits' adding a 1.4x III to the 24 gives 34mm which is basically the same and the IQ is pretty similar too.
Yes, the new version is that much better; I had the Mk 1on an original 1Ds (12mp) and changing ups the made a bigger difference to overall sharpness and quality than the original TS-E going to 21mp on a 5DII.
Thanks in advance
In addition; the 45mm TS-E is better than it's reputation would suggest, and the old non-L version of the 90mm is a good enough lens on my 5Ds that I can't see a need to update.
Finally, I am currently experimenting with a Bronica PS 65mm on a Fotodiox shift adapter for a current project, and it's looking very promising right from wide open.
Canon TS-E 45mm Sample
Just to show what the 45 is capable of...
Zeiss 35mm PC-Distagon
This is from the Zeiss C/Y 35mm PC-Distagon...
OP AceVentura0212 Regular Member • Posts: 117
Re: Zeiss 35mm PC-Distagon
Thank you, both. On reviewing the posted photos I pretty much have concluded that 24 is an appropriate FL. I routinely shoot w a 50mm and can see that the photos, while lovely, require more distance than I’ll have. 24 is The Goldilocks FL, I think.
As to the I vs the II, well, all comments and reviews point toward the Mk II, which I guess explains the premium price.
Thanks again for your input.
Nick5
Nick5 Senior Member • Posts: 1,664
I bought my 24 Tilt/Shift II in 2014. Debating between that and the 17. The 24 seemed to be a bit more universal and not a specialized as the 17. Will pick up a 17 soon, but the 24 is a great base to start with.
Enjoy.
 Nick5's gear list:Nick5's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon TS-E 24mm f/3.5L II +8 more
Thanks.  Got a birthday coming up so this might be my present to myself.
Rodger in Edmonton
Rodger in Edmonton Veteran Member • Posts: 4,601
Thanks in advance
I have both 24 II TSE and the 17 Mark I and would go for a 17.
The 17 gives more room for composition, there is more edge distortion but IMHO, very soon the 24 II will be presented with a cramped situation.
You can be almost right on top of such structures with a 17 .
Better a bit too much FOV than too little and the 17 is far superior for general urban scenes
Only a tilt shift will render proper verticals, Tilt shift do not stitch per se, since the images are on the same focal plane on the X & Y axes,  they merge with no seams or artifacts if your X - Y alignment is correct.
This is a 24 II inside.
Best Regards, Rodger
Save Lives - Be an Organ or Stem Cell Donor.
Quaecumque vera
