2-4 speedlights, or a Nikon R2D2
sanosai wrote:
I just realised I m doing something wrong here. Or at least, there is something I could be doing better
My macro setup: 90mm Sony macro on A7RIII + 2 to 3 (diffused Godox TT350s)
That's a decent setup.
From within the camera setting, I m mostly using the flash for 'fill'
Flash is set to TTL
Macro flash is very confusing for TTL systems: you might want to get good with manual.
But now I realise that I ve totally overlooked the 'zoom' setting on my TT350 units - it was always set to 24mm! So basically, all that time I m having a much broader lighting than I should have (+wasting battery??)
As BBbuilder467 pointed out, you really only care about that when a flash is directly facing a subject and is at the same distance as the subject. With diffusers you want to zoom the flash to fully illuminate the diffuser, which probably means your widest setting.
Without diffusers (like when I do cross-polarizer work) you want to adjust for distance differences. For example, if you're using a 50mm lens, and the subject is 10cm from the lens, but 30cm from the flashes, you could set the flashes to 50cm * (30cm/10cm) = 150cm to get maximum output from the flashes. Note that the flashes have to be aimed well. If you're not aiming accurately go for a wider setting: 100mm or maybe even 50mm.
From what I understood, this flash zoom range, needs to match the focal length of the lens (in which case, 90mm..). The TT350 doesn't allow to set me zoom precisely to 90mm - it goes to steppings i.e. 70mm, 80mm and 105mm (which is max). So I have set it to 80mm, which is the closest match, as I also thought setting it to 105mm would be too narrow
Again, the "perfect match" doesn't mean anything unless you don't have diffusers and you're subject to lens distance matches your subject to flash distance.
Although there is no 'best setup', as it all depends of the shooting scenario and adjustments will be needed from time to time - but is there a 'go to' setup that I could use? At the moment, I don't feel confident to go full manual with the flash, hence I opted to leave it to TTL
I assume you have some sort of brackets for the flashes that hold 2 or 3 flashes to the camera. If so, shoot a few shots on manual with a subject you like, read the histograms, and adjust the flashes until you get a satisfactory exposure.
Now write those flash settings down.
Boom! Done!
For starters, am I approaching this right, by setting the flash zoom to 80mm? There also seems to be an 'auto-zoom' function on the TT350s, but I was hesitant to have it decide on the zoom,
It doesn't "decide", it tracks the lens setting. Zoom in or out and you'll hear all the flashes zoom to match.
hence preferred the manual option of 80mm..
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
