RP stuck in Manual Focus mode?
Started 2 months ago | Questions
Wiedehopf Junior Member • Posts: 38
After taking a few shots with the RF 24-105/f4.5-7.1 in manual mode (using "centre focus macro"), the menu for 'focus mode' allowed only to select 'M' option- the 'AF' option was completely greyed out (the mode dial was set to Fv). I tried changing the dial to 'M' mode and nothing seemed to work - power off/on, go out of menus etc., until I powered off and removed the kit lens and put on the RF 50/1.8.
When I then did the same shots with my EF 60mm/f2.8 macro I had no further problems. I have other issues with modes and weird behaviour with the 24-105 kit lens; not with any others. That was bought of E-bay in 'as new' condition (unwanted in a kit set).
1. Should I be worried or has this happened to others? The camera is still under warranty.
2. Is this likely a specific issue with my RF 24-105 kit lens? Not much I can do in this case. I have used it before in MF without any such issues.
Any help or advice much appreciated. Really enjoy all the threads and discussions. Great forum for new R-mount owners like me.
 Wiedehopf's gear list:Wiedehopf's gear list
Canon EOS 60D Canon EOS Rebel SL1 Canon EOS RP Canon EF 24mm f/2.8 Canon EF 35mm F2.0 +11 more
cmcm789 Regular Member • Posts: 293
Re: RP stuck in Manual Focus mode?
This problem sounds familiar. I have the same kit. I think there is some issue that once in Manual Focus you have to dive deep into the camera menu to find and change back to AF.
This is why i prefer back button focus where i can set the focus independently from framing and taking the shot.
Wingsfan
Wingsfan Contributing Member • Posts: 678
You'll have to look online for more specific information, but you probably inadvertently went into the 'semi macro close up focus mode'- my name for it, not the official Canon name- but if you search you will find it. You have to move the focus ring back to a certain point and then you can re engage the auto focus function on the camera body.
 Wingsfan's gear list:Wingsfan's gear list
Fujifilm FinePix F31fd Nikon Coolpix 4100 Canon PowerShot S95 Olympus XZ-1 Nikon Coolpix S9100 +24 more
gscotten
gscotten Senior Member • Posts: 2,498
Yes, when using Center Focus Macro you have to turn the focus back to infinity to get out of it.
George
 gscotten's gear list:gscotten's gear list
Canon EOS RP Canon RF 24-240mm F4-6.3
