Strange image shake on R7
Circa1200AD New Member • Posts: 6
Hello all,
I'm new to the forum but have been shooting with Canon DSLRs for 15+ years. I just got an R7 a month or so ago and have noticed a strange thing with my images: there appears to be noticeable image shake even when the shutter speed should be high enough to avoid shake without IS. And the shake seen in the images isn't the smooth blur you often get with an unsteady hand but rather it's like a double image. Am I doing something wrong with the R7? Is there a setting I've missed or screwed up?
Below are 100% crops from the R7, all handheld at f/5.6 and 1/80th with focal lengths around 22-28mm (except the 100-500mm shots). I've used a variety of lenses (Canon EF-S 15-85mm, Canon EF-S 10-22mm, Canon EF 28mm f/1.8, and Canon RF 100-500mm) with the EF and EF-S lenses using a Canon EF-RF adapter.
F/5.6, 1/80th, ISO 800, 100% crop, 22mm
F/5.6, 1/80th, ISO 800, 100% crop, 28mm
F/5.6, 1/80th, ISO 800, 100% crop, 100mm
 Circa1200AD's gear list:Circa1200AD's gear list
Canon EOS 7D Canon EOS R7 Canon EF 28mm f/1.8 USM Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM +2 more
Canon EOS R7
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
Re: Strange image shake on R7
What shutter mode are you using? The R7, like most other mirrorless cameras, can experience some shutter shock at those shutter speeds with full mechanical shutter.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
J.K.T. Contributing Member • Posts: 512
I'm hearing this a bit too frequently. I have to wonder if Canon has made a bit of a design fib with the shutter stock and IBIS. They don't have that much experience with IBIS on cameras with fast rate and the smaller sensor is considerably lighter than FF...
Naturally just is just speculation with no hard facts behind it. It is just the kind of mistake that could be made and would explain these reports.
 J.K.T.'s gear list:J.K.T.'s gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS R7 Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM +15 more
Kokopelli_Rocks
Kokopelli_Rocks Veteran Member • Posts: 3,661
I agree with Alastair. If you are using the mechanical shutter I recommend trying speeds of 1/200th or greater and see if it goes away. Also, you might want to try ES.
 Kokopelli_Rocks's gear list:Kokopelli_Rocks's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Sigma 14mm F1.8 Art Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +15 more
Dave C 150 Regular Member • Posts: 320
Hmm. I've been using electronic shutter in servo mode , H burst (not H+) and have found that in a group of several images at high shutter speeds over 1/500 sec on relatively static subjects some are out of focus. In fact they have virtually the same time stamp and also the whole image is blurred including the background.  I have also found that sometimes I can have a focus point on a flying bird on the eye and some frames are dead sharp but others it has jumped for no reason to the background yet the focus point is still showing on the eye on the playback image. This is with RF 100-400mm with IS and IBIS enabled. All rather odd.
 Dave C 150's gear list:Dave C 150's gear list
Sony RX10 IV Pentax Q Nikon D500 Canon EOS R7 Sigma 105mm F2.8 EX DG OS HSM +6 more
Alastair Norcross
This isn't a Canon thing. Shutter shock is common with mechanical shutter on all cameras at certain shutter speeds with certain lenses. If this is shutter shock (we haven't heard back from the OP what the shutter mode was), this is perfectly normal. Shutter shock doesn't affect all lenses equally. For example, on the Canon M6II, I've only ever seen shutter shock on IS lenses, and even then the amount varies between lenses. The older the lens and IS mechanism, the more I'd be worried about shutter shock.
Yes.
If this is shutter shock, caused by mechanical shutter, there's no mistake. Canon included three different shutter modes on the R7. Use EFCS or e-shutter at the affected shutter speeds with the affected lenses. I never use full mechanical on my R7. There's no reason to, unless you're shooting at really high shutter speeds with very fast lenses (such as F1.4).
Alastair
Alastair Norcross
That is odd. I've never experienced that myself, and I've shot a lot in e-shutter in servo H burst mode and fast shutter speed. But whatever is going on with you, it's obviously different from what it going on with the OP.
Alastair
Steve Fink Senior Member • Posts: 1,652
Just curious as to whether you use BBF (back button focus) or half press shutter button focus.  I haven't had much opportunity as of yet to have a good run at BIF shots.
Steve
Minds are like parachutes, they only work when they are open - Unknown
Sorry to be off topic a bit but there are a mounting number of R7 AF issues threads. I'm still experimenting but there are a lot of variables that I can't get my head round. LIke today, to pass the time whilst a car passenger I turned off servo to single shot, turned off subject tracking, subject recognition and eye recognition. Put it on single point focus. Pointed it at the number plate ahead of the car going at about the same speed as us. Pointed and got white square over the number plate then pressed bbf to focus and it jumped with about 7 red squares straight to the centre reservation rails !! I can't find a way of covering something I want to shoot and it permanently staying there. What is going on? Then back on site and with the preferred settings from "Ron's" Whistling Straits video tried to get an owl not too far away flying slowly, against the sky. Seemed to get red squares over owl but on viewing not in focus and no focus points showing at all . Then a few seconds later against a fairly distant grass background it managed to focus on about three out of five in the burst.
Probably need a new thread.
Alastair Norcross
That sounds like you had BBF set to engage other settings. If you are in one shot (not servo), no tracking and no eye detect, and using single spot (either small or big), the focus will stay inside that spot. I've just tried it with mine, and I can't induce it to focus on anything outside of the spot. If you're in one of the zone modes, you will see the multiple focus squares inside that zone (it has to pick something to focus on inside the zone), but nothing outside the zone. You should check your custom settings to see what you had the BBF button set to. This isn't a problem with the camera, but with your settings. Or, it might be that you have a faulty camera, but what you are describing doesn't happen with a non-broken R7, unless you had programmed the back button to use other settings. If that's the case, it doesn't matter that you turned off the other settings.
What I have done is program my AF-ON button to use the "register/recall" settings, and set it to single spot (small) with no eye AF and no subject tracking. That forces the camera to focus just on what's under that spot (I can use it with one-shot or servo). It stays there. It works perfectly. I don't use it often, because I find the subject and eye-detect and tracking of the R7 to be superb. But occasionally I need to force the camera to focus on a particular thing, and that's a quick and easy way to do it.
What is going on?
It really sounds like a problem with your settings. You might want to reset everything and start over.
Alastair
Thanks Alistair. I have a feeling you are right. Having tweaked many settings and customised buttons I may have something in there that I'm not fully aware of its function. Whilst I am an experienced photographer the nuances of mirrorless and the R7 still require some deeper study I feel
What is going on?
Alistair - big thank you. I discovered I had somehow set bbf to eye detect which would presumably be responsible for almost all of the above problems and some others as well. It seems ok now with a quick test. I was toggling eye detect on and off with the M-fn button when tracking but would the bbf button always overrride this when I pressed it o focus when it was set as above. It appears so.
Thanks again, I will get there.
Alastair Norcross
What is going on?
Glad you figured it out. I think the learning curve for mirrorless, coming from a DSLR, is quite large, especially with a complicated AF system like the R7’s. I eased myself gradually into mirrorless, shooting several M cameras (M, M6, M6II) alongside my 7D and 7DII. And then my first R was the R, which has a less complex AF system than the R7. Even so, I’m still learning the R7 after six months of use. I’m pretty comfortable with it now, but still occasionally tweak my settings.
Alastair
OP Circa1200AD New Member • Posts: 6
Sorry for the slow response, apparently I hadn't turned on notifications yet. Yes, I'm using full mechanical shutter to avoid any rolling shutter on higher shutter speed panning shots. This is the first I've heard of shutter shock, guess that's probably an IBIS thing as I never had an issue like this on my old 7D (where I'm coming from). I'll give electronic shutter a shot, hopefully that fixes it.
Thanks!
mohdya Senior Member • Posts: 1,265
Circa1200AD wrote:
Hello all,
Here's what I found in the R7 manual. As a safety precaution (even though this may not be applicable), I enabled the shutter release w/o lens to ensure IBIS works. Hope this helps. It's also telling you that there is an issue with comms. between lens and camera, if enabling resolves your problem.
Yus.
'Photography is the Art or Process of Producing Images,
The Art of Photography is Another Story.'
http://www.flickr.com/photos/mohdya/
 mohdya's gear list:mohdya's gear list
Panasonic Lumix DMC-TS5 Canon EOS 70D Canon EF-S 18-135mm F3.5-5.6 IS STM
koenkooi Contributing Member • Posts: 920
EFCS has no rolling shutter either and has no shutter shock for the first picture in a burst and significantly less shock for subsequent pictures.
On your 7D you could enable 'silent shooting' to get EFCS, it improved my macro shots a lot. When shooting through liveview on a 7D you get EFCS by default, and no mirror slap. Shutter shock was a thing, but mirror slap was an even bigger issue. The extra weight of the 7D compared to the R7 also helped with dampening the effects.
Anyway, it looks like every Canon IS system, be it in-lens or in-body, handles shutters speeds roughhly between 1/60s and 1/160s badly. You'll see sharpness increase with faster speeds (as you'd expect), but also at slightly lower speeds.
The EF600L III owners created enough noise for Canon to send out a lens firmware update to make it better, but that has been the only time Canon did anything to acknowledge or improve this behaviour.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
gianstam Senior Member • Posts: 1,072
Repeat your test in burst mode
capture a few pictures and see if the problem exists after the first picture
 gianstam's gear list:gianstam's gear list
Nikon Coolpix 990 Samsung TL500 Canon PowerShot G1 X Pentax K20D
Re: Repeat your test in burst mode
I feel like I was seeing this effect during burst with a full mechanical shutter, but I'll definitely be playing with the electronic shutter settings and testing it again.
Steve Balcombe Forum Pro • Posts: 15,571
Ah, no, rolling shutter problems are due to (or at least greatly increased by) the slow sensor readout in ES mode. Use EFCS all the time unless you have a specific reason to use one of the other modes.
Also BTW rolling shutter has nothing to do with shutter speed.
David Yule Regular Member • Posts: 318
That setting will only affect things where the camera can't detect a lens e.g. one with no electronic interface, which are usually manual focus lenses/adapted lenses.
David
