fly in my x-h2 500mm pf ointment.
3 months ago
I got my Fringer adapter yesterday and starting taking some test shots with the 40mp sensor behind the Nikon 500mm pf lens. When I first looked at the ooc jpegs, I was excited...I was seeing detail on my dollar bill test chart that I hadn't noticed in years of shooting that same chart with dozens of camera/lens combos.
Then, I processed raw files in DXO (using presets with no customization on my part, which is my usual workflow) to compare to other shots and was disappointed. After a more careful examination of my process, I noticed that DXO is not applying an optical module to the new files because, presumably, of the mismatch in manufacturers. This means no lens sharpness (tailored to the lens based on DXO's extensive testing) is being applied (only global sharpness/usm). Maybe I can get back to where I was by increasing global sharpening to make up for the lack of an applied optical module.
When I started using DXO a year ago, I felt it was a large step forward in image quality--less noise with more sharpness rather than the usual trade-off between the two. It looks like whatever magical recipe DXO was using to help me take this leap forward will not be possible with the mis-matched manufacturers.
I know some people are using other Fuji cameras with this lens, has anyone struggled with this issue?
I guess I may end up having to use DXO for noise reduction and LR for sharpening. This is an unwelcome extra step, and I don't like LR's sharpening of Fuji files nearly as much as that from DXO.
I'm afraid that I'm giving back the advantage that I would otherwise have gained by putting this beast of a sensor behind this beast of a lens.
More testing is on the agenda for today.
