Adapted Nikon Lenses on X-H2/X-T5 and X-H2S
Peter M J Contributing Member • Posts: 802
Re: Adapted Nikon Lenses on X-H2/X-T5 and X-H2S
I have a few Nikon F lenses and they all work perfectly through the Fringer- it was the option to use these that helped me to settle on the XH2s as I saw no need to buy additional lenses . The ones I have used most are the 300 PF ( with the 1.4 TC111 ) , the 500 PF and the 18-105 which is a cheapy lens
This was with the 300PF nikon lens
Regards Peter
 Peter M J's gear list:Peter M J's gear list
Nikon D850 Nikon Z7 Nikon Z6 Fujifilm X-H2S Nikkor AF-S 300mm f/4E PF ED VR +3 more
Morris0
Morris0 Forum Pro • Posts: 32,181
dezinerd wrote:
I have an all manual Viltrox adaptor and it rotates on the locking pin a couple of degrees and it can also wobble on the mount. It drives me crazy. Is the Fringer tight fitting? One other question how are the firmware updates done?
It is hard for me to justify the expense of the adaptor when I only have six afs Nikkors and there are native fuji replacements that can be bought. The tanking of Nikkor lens prices also complicates this deal. Realistically those prices aren't going where they were in the past. My stabilzed 16-35 f4 is unique to Nikkor but it is a tank. lol
The Fringer adapters have a very tight fit.  Firmware update of the Fringer adapter is super simple.  Attach the adapter to your computer via USB and it appears as a USB drive.  Copy the firmware to the drive and in a moment the adapter will detect the new firmware and install it.  The USB drive vanishes when the firmware update is complete.  If you attach the drive again you will see a file with the firmware version number so you can tell the update happened.  The firmware number will also be visible on your Fuji body if you power the camera on while holding down the disp button the same way as done for Fuji lenses.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
