EOS R6 Mark II firmware version 1.1.1
SurettePhotography Junior Member • Posts: 31
Firmware version 1.1.1 incorporates the following changes.
  1. Adds supports for the Speedlite EL-5.
  2. Reduces start-up time when the camera's Bluetooth setting is enabled.
  3. Allows FTP/FTPS/SFTP transfers to be completed when using an IPv6 setting.
  4. Fixes minor issues.
https://canoncanada.custhelp.com/app/browse/a_status/published/channelRecordID/DRIVERS_AND_SOFTWARE/pageSize/25/productCategoryAnsList/RN_PRODUCT_3365%3ARN_CATEGORY_2652%3ARN_CATEGORY_319/productRecordID/RN_PRODUCT_3365/truncate/200/type/browse
Canon EOS R6 Mark II
MyM6II Senior Member • Posts: 2,424
Re: EOS R6 Mark II firmware version 1.1.1
๐Ÿ‘
l Just opened the Camera Connect app on my phone and it tells me that there is a new firmware and an option to download it. When the download is finished, it transfers it to the camera and tells me to continue the process on the camera. The camera is now displaying the update menu and I just have to select “update”. Cool! It can’t be much easier than that.
And yes, the startup with BT enabled is much quicker.
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
Rik_C Junior Member • Posts: 28
Also update here via de smartphone app, Canon has finally exited the '90s regarding the software update process for their camera's it appears.
And indeed, noticeably faster powering on with BT enabled
Ephemeris
Ephemeris Senior Member • Posts: 1,186
I've been posting about this for ages and basically got ignored ๐Ÿ™ˆ
Mark B.
Mark B. Forum Pro • Posts: 29,742
Does this work for the R6 v1 also?
Well the smartphone app was completely updated recently, so maybe? Best to test yourself.
Ephemeris
Absolutely.
Tazz93
Tazz93 Veteran Member • Posts: 3,473
Seems unnecessarily risky
MyM6II wrote:
๐Ÿ‘
I hate to be "That Guy", but honestly... starting a firmware update over a phone's Bluetooth/WiFi connection seems like the worst possible solution, IMO. Maybe they have an air-tight file checking system which ensures there are no copying errors (from the servers to the phone AND the phone to the camera), but that convenience just seems unnecessary to me. Updating firmware is not really a 100% safe thing to do. There is always a risk of corruption and failure, in which case, the camera would need to be flashed by Canon or the board replaced.
IMO, saving the file to the card media and inserting it into the camera just seems faster and safer (not including PC boot up time). IMO, this just seems like a solution in search of a problem. I am an IT guy and it is relatively rare to see a problem with firmware updates, but my experience will keep me from ever trying this.
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
Ephemeris
Re: Seems unnecessarily risky
Tazz93 wrote:
MyM6II wrote:
๐Ÿ‘
The update is done from the memory card. The phone simply put the data on to it.
It's great.
Possibly but it's the same risk as from a card I think.
It's the same but the app tells me when a new versions is available, does the work for me.
Tazz93
I have no issues with this part, definitely a plus, but my take is, its just not worth the risk.
Also, is it really faster? Canon's file transfer system implementation is not as good as I would expect. All the transfer protocols seem woefully slow, the only exception is the downsized image file transfers to the phone from the camera. Those seem reasonably quick, even if compressed and downsized.
Ephemeris
What is the added risk? Your camera updates from the one and same file on the memory card.
So added benefit no risk?
It downloads pretty quick.i don't have to hunt for the right file. I get told about the update. I don't need a laptop/pc with me or booted up.
Peace of mind, I get asked of I want a newer version and if I decide yes then it does it for me.
It doesn't speed up how long it takes the camera to actually update of course.
If folk don't wish to use it then great. We use a lot of WiFi image transfers so getting asked is part of the deal.
Tazz93 wrote:
MyM6II wrote:
๐Ÿ‘
I don't see this as an added risk. More the opposite. I get the correct file, and the app and camera do the job for me. They are designed to work together. Less chance for me to mess things up.
I am not worried about this at all. It is great.
A_Mist
A_Mist Contributing Member • Posts: 988
Does this update reset my camera back to factory settings, or are my custom settings and button mapping safe?
 A_Mist's gear list:A_Mist's gear list
OM-1 Canon EOS R6 Mark II Olympus 12-100mm F4.0 Canon RF 50mm F1.2L USM Canon RF 24-105mm F4L IS USM +4 more
no
Yes. They are safe.
๐Ÿ‘๐Ÿ˜ƒ
