EF-M 18-150mm IS STM and M6 II
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,481
Is the 18-150 capable to resolve the 32MP?
I feel that my sample is good on M1, but less so on M2.
All primes seem to shine though.
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
Canon EOS M6
KEG
KEG Veteran Member • Posts: 4,909
Re: EF-M 18-150mm IS STM and M6 II
Works fine on mine.
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
Maxmolly7
OP Maxmolly7 Senior Member • Posts: 1,481
KEG wrote:
Works fine on mine.
It is probably the best non-L zoom I used so far and, yes it works, but it seems to miss some punchy character?
davev8
davev8 Veteran Member • Posts: 4,833
the M1 and M2 are both 18MP they should look the same
if you are happy with the results with any lens on 18MP if you view the photos at the same size they will look better with 32MP
Attention Dislexsic i mean dyslexic person... This post will have many although spell checked, spelling and grammatical errs ..its The best its going get so no need to tell me it is bad I know it is .....................................................................................................
the EOS M is not dead and wont be for a long time ....as long as you don't want a flagship camera with a VF...if that's the case it died sometime ago
My 5D IS a MK1 classic
There is no argument for FF vs APS-c (or m43) with shallow DOF..as it's a law of physics and a very subjective personal thing if you want to make use of the shallow DOF only FF can offer
If you wait for a camera that will  tick all your boxes ....by then you will have more boxes to tick..... so the wait continues .....David Appleton
 davev8's gear list:davev8's gear list
Canon EOS 5D Canon EOS R6 Canon EF 50mm F1.4 USM +5 more
KEG
Maxmolly7 wrote:
KEG wrote:
Works fine on mine.
it is nice and sharp, even wide open on both ends of the focal range, there is nothing more to complain.
I have both 24 and 32 MP but have found almost zero reason to do an indepth analysis of them.
KEG
Maxmolly7
I meant M 6 Mark I and II. 24 vs 32 MP.
Maxmolly7
KEG wrote:
Maxmolly7 wrote:
KEG wrote:
Works fine on mine.
Thanx KEG for this. I may have deeper look myself and run a benchmark when time permits.
thunder storm Forum Pro • Posts: 10,139
24Mp is more forgiving. You're IQ isn't getting worse with 32Mp, in fact a little better, but smaller pixels allow for peeping harder.
If you shoot compact zooms only 24Mp might make more sense, even though these lenses benefit as well from a higher Mp-count. The gains are smaller with compact zooms, while the files do get bigger.
If you shoot primes as well those bigger files are worth it. The M6II also has a better dynamic range, and this will improve the IQ even with softer lenses.
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
Maxmolly7
Good answer,  thanx.
Poulty Regular Member • Posts: 130
I was disappointed with two copies of the 18-150 that I went sold them and went back to the EF-S 18-135 USM, far better results. Yes heavier and larger but worth it IMO.
 Poulty's gear list:Poulty's gear list
Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon 70-300 F4-5.6 IS II Canon EF-M 18-150mm F3.5-6.3 IS STM +1 more
Alexis
Alexis Senior Member • Posts: 1,998
For my "tele" needs I tested both the EF-M 18-150 and the EF-M 55-200 and I chose the latter despite it being an older lens (2016 vs 2014).
My non-scientific tests on an M50 showed that the 55200 was better optically and I appreciated the extra reach.
 Alexis's gear list:Alexis's gear list
Canon EOS 50D Canon EOS M50 II GoPro Hero9 Black Sigma 17-50mm F2.8 EX DC OS HSM Canon EF-M 11-22mm f/4-5.6 IS STM +12 more
RLight Senior Member • Posts: 4,416
The question needs to be reordered, can the 32MP resolve the 18-150, yes. It does so better than the 24MP M5.
These have the same resolving power. AF is quite improved on the M2, obviously the M6 II wins here.
Primes do better than zooms, period. But then again they can’t zoom necessitates a prime swap…
I say this having owned all the above, not just regurgitating what others have said.
Too bad they don’t make a zoom that’s as good as a bunch of primes… If only Canon did, it’d be $3000, weight 1400g and be in the RF mount. Tongue in cheek aside, this whole 32MP vs lens thing is a total misnomer. I personally love the 18-150 and 22 pancake combo on the M6 II. If only Canon gave the R platform an R8 and RF-S 22mm…. They may btw, it’ll be 24MP though if I was betting…
 RLight's gear list:RLight's gear list
Canon EOS R3 Canon EOS R50 Canon RF 28-70mm F2L USM Canon RF-S 18-45mm Canon RF-S 55-210mm F5.0-7.1 IS STM
Maxmolly7
Thanx for adding this, btw I meant M6 mark 1 & 2, not M and M2 bodies.
I tried RP with 24-240mm zoom but did not like the bulk, so I rather bought M6 II used at as great bargain.
The RF24-240 is unwieldy, even on an RP. The M6 II + 18-150 is really “fun”. I’m hoping Canon does an M6 in RF form so we can have that 18-150. But again, it needs a 22 to go with it. That FF RF 24mm is too big for compact “fun” use. I haven’t tried it but it’s the same size as the RF35, which I had.
KEG
Looked at my M6 i and ii photos in Lightroom, pretty much no difference between on my MacBook Air screen
KEG
Maxmolly7
R2D2 Forum Pro • Posts: 26,528
Maxmolly7 wrote:
KEG wrote:
Maxmolly7 wrote:
KEG wrote:
Works fine on mine.
Well “character” if that’s what you’re looking for, isn’t something you can really benchmark.  A lens may be sharp enough, or fast enough to perform the tasks you ask of it (which the 18-150 is for me in its limited role).  But ask it to change its character and it’s a no-go.
Character must be built into a lens’ design.  All of the decisions that affect/influence character are made before the lens ever gets built.  So unfortunately if you’re looking for a different character than what the 18-150 is delivering for you, you’ll simply have to choose a different lens.
Best of luck in your quest!
R2
KEG
There is something strange with mine, exif reports only 141 mm at tele... or is it Lr?
KEG
R2D2 wrote:
Maxmolly7 wrote:
KEG wrote:
Maxmolly7 wrote:
KEG wrote:
Works fine on mine.
R2
Maybe it was more about punch (or the lack of punch) and less about character.
When looking for punch compact crop zooms will be compact crop zooms. Nothing wrong with it. But primes will do better.
KEG
A unholy combination of Lr UI on Windows 10 through Microsoft Remote Desktop, 150 mm didn't show up in the focal length browser :/
KEG
