What would you do
Barry Reynolds
Barry Reynolds Regular Member • Posts: 243
What would you do
I took this photo with a 28mm lens at f11, 1/60 ISO3200. I like the composition but the building in the background aren't that sharp in the full res image.
I think ISO 3200 is the limit I would want to push the 6D, and same with 1/60 second so f11 is the only choice.
It could be a case of taking it in better light or would a wider lens give more depth of field but still a suitable composition? Perhaps focus stacking?
 Barry Reynolds's gear list:Barry Reynolds's gear list
Canon EOS M6 II Canon EF 85mm F1.8 USM Canon EF 70-200mm F4L USM Canon EF 35mm F2 IS USM Canon EF-M 11-22mm f/4-5.6 IS STM
Canon EOS 6D
Rodger in Edmonton
Rodger in Edmonton Veteran Member • Posts: 4,601
Re: What would you do
Remove the dog and boat and focus on the architecture for 1 shot and the dog a portrait
The dog is best done as a majestic portrait - his look would be a stunner - not so much here, likewise the bridge as a stand alone is very attractive in composition and lines.
The two forms do not naturally mix.
Best Regards, Rodger
Save Lives - Be an Organ or Stem Cell Donor.
Quaecumque vera
Marquee Regular Member • Posts: 407
I would have walked further along the south bank from Canon street bridge to Tower Bridge (with a very distinct, iconic shape, framed a similar shot but got lower to be more in line with the dog and shot a wide aperture like F2.8 to make the dog the subject and the bridge nicely out of focus but recognisable.....
Only slight problem is there is no railing there so the dog might fall in the Thames!
 Marquee's gear list:Marquee's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.0 USM Canon Extender EF 1.4x II Sigma 50mm F2.8 EX DG Macro Canon TS-E 24mm f/3.5L II +4 more
gaul Senior Member • Posts: 1,505
Hello Barry,
Photo works for me, nice composition, nice dog
Maybe not very sharp, but still a nice pic
Also have the old but faithful 6D .. nice for portraits and also low light
I take it you have the EF 28mm F/1.8 non-IS version.. and not the EF 28mm F/2.8 USM IS version
Rgds, Gaul
 gaul's gear list:gaul's gear list
Canon PowerShot S30 Canon PowerShot G1 X Canon EOS 6D Panasonic Lumix DMC-GM5 Canon EF 50mm F1.4 USM +7 more
Barry Reynolds
OP Barry Reynolds Regular Member • Posts: 243
Thanks. I've got the 28mm IS USM. For black and white I don't like to have blurred background, or certainly not blown out at f2, but for colour I like that.
The 28mm IS is very sharp but it probably doesn't show here. I've tried focus stacking and that seems to be the answer by taking 3 shots whilst moving the focus so the foreground, mid and background are in focus (3 shots) then merge them.
I tried this hand held and it came out very good. The lens is very sharp at f2.8 but even better at f4 which I'd prefer to shoot at.
Barry Reynolds
He's ok without the railing, he's use to walking across bridges with high walls as he grew up in the Alps so height doesn't worry him.
I work near London bridge so I'm trying to find better spots but just trying out scenes now so I can get everything in focus. I prefer the details in Black and White to all be in focus, of light bokeh as I think the details in the background add to the image where as in colour they can be a distraction.
I take thousands of shots with Murray in locations all around Europe. The 28mm lens is great and there are many possibilities such as creating panoramas, focus stacking or using low shutter speeds such as 1/15 or 1/30 which I'd never normally use. I can't always choose the location as it's more taking what I see as I walk around.
The boat was intentional with his head between the bridge spans and trying to capture new (boat), industrial (bridge), modern city (sky scrapers) and the old (church type building - thinking about it now, they may be one of my web design clients)
The image is cropped for instagram but I'm trying to not crop vertically, although it has a slight vertical crop.
London is very buy so it's trying to get the details in as best I can to a composition but it still needs work.
I've just bought a monopod so that should help with focus stacking.
BAK Forum Pro • Posts: 26,019
Look up "hyperfocal distance."
Hyperfocal distance is the focus point where infinity is sharp, and the sharpness then extends toward the camera. The near end of sharpness is the near end of the hyperfocal distance.
I don't have charts, or lenses with hyperfocal distances on them, although I do have two dogs.
Anyway, by focusing between Murray and the far building, we may get both of them sharp.
BAK
John Crowe
John Crowe Veteran Member • Posts: 3,476
Focus stack, or tripod, or wait 'til daylight.
I can see the lights in the buildings so this must have been taken at dusk, so a lot to ask for a photograph.
Given this exact situation the only thing you can do is focus stack which will work extremely well. Focus on the dog, and then maybe three more images working your way to infinity.
Otherwise, wait for daylight and use f22 to f32. With rear view magnification and the stop down button you can determine which focus distance and aperture will get everything in focus. You might get away with 1/30s with that lens. Get ISO as low as possible.
If you want to do it at dusk/dawn you will need a tripod. If the dog is reasonably still you can get down to 1/20, f22, lowest ISO possible.
Ultimately focus stacking will be easiest.
P.S. Since I know now that you have IS, you should be able to get down to 1/20, to get to f19.  This is what IS was meant for.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
Messier Object Forum Pro • Posts: 12,711
the sharpness of the background doesn't worry me as much as the bow of the boat on the left side of the image.
To my eye the boat seems to unbalance the composition - it impinges on the dog  - takes my eye away from the dog's face
I would clone out the boat or retake the image when the water is clear of traffic
Peter
 Messier Object's gear list:Messier Object's gear list
Nikon Coolpix 990 Olympus C-5050 Zoom Olympus E-300 Olympus E-330 Olympus E-30 +31 more
