EF 16-35mm f/2.8L III vs EF 35mm f/1.4 II Sharpness
jcee724 New Member • Posts: 5
Hello guys quick question... Is the ef-16-35 iii at 35mm sharper than the prime EF 35mm f/1.4 ii?
BAK Forum Pro • Posts: 26,020
Set them both...
Set them both... at f 5.6 or f.8, print both pictures on premium glossy ink jet paper with OEM inks, and you won't be able to see any difference that matters.
BAK
OP jcee724 New Member • Posts: 5
Re: Set them both...
Thats not directly answering my question and I don't make prints. I just want to know which lens is sharper.
Trevor Sowers
Trevor Sowers Senior Member • Posts: 1,605
I think the point that BAK is making is that it doesn't matter which one is sharper.  Is there a specific reason that sharpness is the only thing you are comparing?  Do you make photo books?  Do you just share on instagram?  Do you make billboards?
So much attention on sharpness when it really doesn't matter for most things.
 Trevor Sowers's gear list:Trevor Sowers's gear list
Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EOS Rebel SL2 Canon EF 24mm f/1.4L II USM Canon EF 35mm F1.4L USM +21 more
No disrepect but I asked a very simple question and I just want a simple from someone who owns or had experinces with both lens I mention. Sharpness matters to me regardless of what its for. Which one is the sharpest ? Thats all i want to know.
Trevor Sowers
jcee724 wrote:
No disrepect but I asked a very simple question and I just want a simple from someone who has or has owned both lenses. Sharpness matters to me. Thats all i want to know.
Yes I get that but you can look that up super easy on the-digital-picture.com
I have a whole bag of L lenses and I seldom see any meaningful difference in sharpness.  Other factors such as flare resistance or handling are actually far more useful differences.
I did check this other site to see and the 16-35 v3 did look sharper at 35mm than the 35 v2 but I wanted to make sure by asking somone who had hands on experince.
gipper51 Veteran Member • Posts: 5,904
Well I've never owned either lens, but according to Photozone's tests:
At f2.8 the prime will win the sharpness contest.
At medium apertures (f4-f8) they'll be so close you can call it a tie. Any noticeable differences will probably come down to copy variation. Both will be very, very good here.
But if all you care about is sharpness, then should probably look at the Sigma Art 35.
 gipper51's gear list:gipper51's gear list
Canon EOS 5DS Panasonic Lumix DMC-GX85 Canon EOS R6 Mark II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +20 more
expro Senior Member • Posts: 2,274
Re: EF 16-35mm f/2.8L III vs EF 35mm f/1.4 II Sharpness
I sold the 16-35iii for the 35Lii on my old 5dsr.
the 35Lii IQ is stunning. The 16-35iii is sharp but not stunning.
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
Pocket Lint Senior Member • Posts: 2,540
But then you just lost all the focal lengths from 16mm to 34mm
I have the 16-35 f/2.8L III and it is THE superlative ultra-wide angle zoom lens for EF mount. It’s sharp, but also has nice bokeh wide open @35mm.
16-35 not stunning? I beg to differ. I find my copy produces stunning results and images
 Pocket Lint's gear list:Pocket Lint's gear list
Canon EOS 5D Mark IV Fujifilm X-Pro3 Canon EF 50mm f/1.2L USM Canon EF 100-400mm F4.5-5.6L IS II Fujifilm XF 23mm F2 R WR +5 more
But not for me. The 35ii has it beaten on transition etc.
You are comparing a very good zoom with one of the very best primes.
I had primes for the other focal lengths. Plus with 5dsr I could stitch or crop if I was caught out.
but really you have to be a 35 length lover.
Canon_Guy
Canon_Guy Senior Member • Posts: 1,489
I do not own any of these lenses but TDP shows the prime is sharper at f/2.8 than the zoom at f/2.8. Not a huge difference but notable. Still an impressive result from the zoom BTW...
Prime wide opened is about the same sharp as zoom wide opened. They seem the same at f/5.6.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
RE>> I just want to know which lens is sharper. <<
It does not matter if you don't make prints. All you are doing is looking at a computer screen.
BAK
Re: Set them both...at the same f stop
You may be able to see one is sharper.
BAK
Re: Set them both...at the same shutter speed
The zoom's optical design may make it slightly less sharp when both are at the same f stop, So if you stop down the zoom by one stop, it'll "catch up" with prime (if you don't change it.
And distance matters.
Anyway, there's been one comment about what I'l getting at.
In addition, when you use the two lenses for comparison by putting the images side by side on monitors, those monitors must match each other in number of pixels and size of pixels. For instance, you need 300 pixels per inch, stretched across 10 inches of screen in a line 3000 pixels "wide" or "across" in order to compare.
So two patches, one from each lens, both 300 pixels per inch for 10 inches horizontal, and 300 pixels per inches high, for, perhaps, 300 x 5 inches (for 1500  high vertical would allow you a pretty good eyeball comparison,
Oh, and you be comparing monitors
Which brings us back to measurement monitoring web site like. optical limits dot com.
I'm going to go a see if that site answers your question. I'll be back.
BAK
Go to opticallimits.com
This is a web site with a lot of lens tests, made with cameras with various sensor resolutions.
It covers both the lenses you mention, with lots of lens apertures, measured wide open and at several small f stops each.
BAK
35mm is one of those love it or hate it focal lengths I think. I used to love it, and it is great for reportage or documentary type of work, but, lately it has fallen out of favour to the good old fashioned standby 50mm focal length. 35mm is a little bit boring and neither here or there as they say.
Trevor Sowers
I tend to prefer a 50 as well   I actually dropped my 35L on the floor Christmas morning this year so it’s out of commission    It put a bit of a damper on Christmas morning for me LOL
Hmm, I might just look into the RF version then lol.
gaul Senior Member • Posts: 1,511
At F/1.4 the image rendering of the prime is no match for the zoom…
Stating the obvious .. but the strength of this prime is to get nice outputs with nice bokeh for a relatively wide focal … sharp straight from F/1.4
QUESTION would be:
1) Have you checked pics at 35mm and F/1.4
2) Do you need or want such rendering?
That would help you decide on which lens to get
Gaul
 gaul's gear list:gaul's gear list
Canon PowerShot S30 Canon PowerShot G1 X Canon EOS 6D Panasonic Lumix DMC-GM5 Canon EF 50mm F1.4 USM +7 more
