Musings about the X100VI, probable april launch?
brian711
brian711 Junior Member • Posts: 27
Re: The NP-W235 is not going to fit...
Maybe to handle a possible 40mp sensor.
 brian711's gear list:brian711's gear list
Fujifilm X-T5
Threaded Veteran Member • Posts: 4,180
How do we know the X100V lens reworking doesn’t already cater for that?  Fuji were reworking and launching other new lenses around the same time that have also since proven 40mp ready.  The X100V designers probably knew what was coming down the track,
 Threaded's gear list:Threaded's gear list
Fujifilm X-Pro3 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR
forest dream Senior Member • Posts: 2,796
Used X100V may popular again
Didn't worry. If next X100VI lens can't cater 40MP sensor, some consumer can buy used X100V again.
Beginners may prefer high resolution (better number in specifications) regardless sharpness.
John Gellings
John Gellings Veteran Member • Posts: 9,743
It’ll be fine on 40mp.
https://www.johngellings.com
Instagram = @johngellings0
 John Gellings's gear list:John Gellings's gear list
Ricoh GR IIIx Fujifilm X-E1 Leica M Typ 240 Fujifilm GFX 50R Fujifilm X-Pro3 +6 more
brian711
Could be.
Fujifilm X-T5
AcerK Forum Member • Posts: 85
Re: Critical specs of X100VI : 23mm F2 lens
nuramori wrote:
I'm going to be the contrarian and push outside the box. I would propose these changes....
Sensor stays at 26mp, BUT goes stacked. Lower noise, faster processing, so biased towards quality at higher iso. Most that are using the x100v aren't pushing the envelope to where more megapixels will benefit them. Also reduces temps for video use.
23mm f1.8 - combined with above, allows for greater use at a wider range of lighting conditions.
new processor, taking advantage of better AF system that's being rolled out.
flippy screen
better evf, slightly larger.
options to also do HEIF in addition to jpg.
Slightly move compact.
slightly better flash specs.
Use the same w235 battery as x-t5, longer usage, standardizing on it.
How is this outside the box? All those things you mention are just generic improvements that comes with every new camera. Also stacked sensor makes absolutely no sense for this compact camera.
 AcerK's gear list:AcerK's gear list
Sony a7 IV Sony FE 50mm F1.2 GM 70-200mm F2.8 GM II
kwa_photo
kwa_photo Veteran Member • Posts: 3,649
Re: Musings about the X100VI, probable april launch?
Good question! If I had confidence that one was coming in the next 3-6 months, I'd sell my X100V at top market dollar right now and stash it away to put towards the new model I am actively considering this, but have a suspicion that the new model may not be announced until the fall and may be available in 2024...just a feeling.  Hmmm....market timing! LOL
Ken
FujiFilm FinePix Moderator (Please PM vs. a public post if you have concerns or questions about the forum)
 kwa_photo's gear list:kwa_photo's gear list
Fujifilm X100V Fujifilm X-T3 Panasonic Lumix DC-S5 Fujifilm XF 50-140mm F2.8 Fujifilm XF 16-80mm F4 +3 more
One more thing
How about physical switch that assign SS dials as either actual SS (default settings in X100V) or min SS (new features in X100VI)?
actual SS or min SS
Stacked sensor bring shutterless only to X100 series, make X100 series more compact/slim.
nuramori
nuramori Regular Member • Posts: 118
Re: One more thing
Stacked sensor also improves AF response, as well as allow for larger light wells for the same size sensor - which means less high iso noise.
 nuramori's gear list:nuramori's gear list
Canon EOS 5D Mark III Fujifilm X-T5 Canon TS-E 17mm f/4L Fujifilm XF 35mm F2 R WR Fujifilm XF 27mm F2.8 R WR +4 more
More noise from stacked sensor
Below article of Fujifilm X-H2s review mentioned more noise from stacked sensor :
https://dpreview.com/reviews/fujifilm-x-h2s-review
"... similar story if we look at base ISO images underexposed and then brightened (as you might when shooting a high-contrast scene). You can see that the X-H2S is noticeably noisier than the X-T4 in the very deepest shadows, and noisier again in E-shutter mode. With less significant pushes, you can see that the X-H2S matches the X-T4 down as far as a +4EV shadow lift, or a +3EV lift in electronic shutter mode.  This essentially matches what we saw with the Nikon Z9's Stacked sensor, compared with the BSI chip in the Z7 II: a very slight increase in read noise as a result of the fast readout being seen as a reduction in usable dynamic range. These differences become slightly larger in the fast burst modes where the camera uses fully electronic shutter..."
John Gellings
Re: One more thing
actual SS or min SS
But the leaf shutter mechanism isn’t exactly fat…it’s why the camera is already thin with the lens.
Auto digital teleconverter framing
How about X100 series that
  • Same size as X100V
  • Shutterless 26MP stacked BSI-CMOS sensor
  • 4-stop IBIS without shutter shock
  • Auto digital teleconverter framing (powered by subject based auto focus and AI) especially high speed shooting mode - camera crop in on a region of the frame and again follow the subject as they move around: panning and scanning to maintain composition
  • Other computational photography (e.g. Live ND, Live composite, HDR+) can shoot together with above auto digital teleconverter framing feature. In other words: Live ND with digital teleconverter is possible.
