How to desert-proof my G1X.II ?
Mark9473 Veteran Member • Posts: 6,425
My daughter's going to the UAE in a couple of weeks and would like to take my G1X.II. Other than leaving the camera at home, is there a way to protect it from dust, or certain things to avoid doing with it? I suppose the lens is drawing in some air every time it is extending?
Mark
 Mark9473's gear list:Mark9473's gear list
Canon G1 X II Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85 Panasonic G85 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +21 more
Jon_T
Jon_T Veteran Member • Posts: 6,393
Re: How to desert-proof my G1X.II ?
You can see if you can find a "Waterproof Case" that will work with the G1X II (e.g., HERE), or consider getting one of the "rugged/ waterproof" type cameras (e.g., HERE).
 Jon_T's gear list:Jon_T's gear list
Panasonic Lumix DMC-FZ200 Canon PowerShot G15 Canon PowerShot SX50 HS Canon PowerShot S110 Leica C +16 more
OP Mark9473 Veteran Member • Posts: 6,425
Not really what I was looking for, but thanks for responding.
Mark
Jon_T
Curious as to what were you thinking of that would "desert-proof" the camera?
Whatever debris that collects on the lens during use will be carried into the camera while zooming; turning camera off.
And as you mentioned whenever (zoomed/ powered on) lens "drawing in some air every time it is extending" and dust on the lens will be drawn into the lens/ camera.
Personally if I cared for the camera, I would not take any camera that did not nave good environmental sealing into dusty/ sandy conditions.
Even with environmental sealing (dust/ moisture), sand getting into a telescoping type lens will probably cause problems.
In such conditions I would a zoom lens that had internal zoom and focus.
Good Luck!
Cyril Catt Veteran Member • Posts: 5,453
Could a mobile phone camera suit your needs?
Cyril
 Cyril Catt's gear list:Cyril Catt's gear list
Canon PowerShot TX1 Panasonic Lumix DMC-LX7 Apple iPhone 13 Pro Max +3 more
If I already knew the ideal solution, I wouldn't have needed to ask
Good Luck!
Thanks.
Mark
Not really, but on the days with noticeable dust in the air that's probably going to be the best option.
Mark
Jon_T
My inquiry was in regards to your reply which I quoted in my reply:
"Not really what I was looking for, but thanks for responding"
would 'infer' you had some thoughts on some possibilities, hence why asking.
Cooter84 New Member • Posts: 6
olympus tough tg6
