Compre una olympus xz-1, se apaga cuando intento borrar fotos, ¿por qué ocurre?
Started 2 months ago | Questions
AndreinaAcv2 New Member • Posts: 1
Compre una olympus xz-1, fisicamente esta perfecta, la bateria se ve bien, venia con una memoria panasonic de 2 gb, tome algunas fotos y logro visualizarlas desde la cámara, pero en lo que presiono el boto para ir al menu de borrar foto, la camara se apaga, tambien si entro en el menu de imagenes se apaga, no ocurre en mas ningun momento. por que puede ser esto? probe la cámara sin memoria y ocurre exactamente lo mismo.
Mod Edit - English Translation from Google follows:
I bought an olympus xz-1, physically it is perfect, the battery looks good, it came with a 2 gb panasonic memory, I took some photos and was able to view them from the camera, but when I pressed the button to go to the delete photo menu , the camera turns off, also if I enter the image menu it turns off, it does not happen at any time. Why can this be? I tried the camera without memory and the exact same thing happens.
Olympus XZ-1
Smaug01
MOD Smaug01 Veteran Member • Posts: 6,966
Please post in English
If you're English is not good enough, please use Google Translate: translate.google.com
Thanks.
-Jeremy
"Rudeness is the weak man's imitation of strength."
-Eric Hofer
 Smaug01's gear list:Smaug01's gear list
Panasonic Lumix DMC-TS30 Ricoh GR III Olympus OM-D E-M10 III Nikon Z5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +25 more
