Canon M6 with 18-150mm lens
Ian Abrahamson
Ian Abrahamson Regular Member • Posts: 460
I am sure this info has been given before, but can some one tell me what F stop number they find is the so called sweet spot on this lens. On a nice sunny day.
Canon EOS M6 18-150mm
power shot SX 50 HS ...Nikon S 9300
Power shot SX 270 HS...Power shot SX 110 is
Fugi Finpix E 500 ... Minolta SRT 101
 Ian Abrahamson's gear list:Ian Abrahamson's gear list
Canon PowerShot SX230 HS Canon PowerShot SX50 HS Sony Xperia Z3 Compact +1 more
Canon EOS M6
Dareshooter Veteran Member • Posts: 5,842
Re: Canon M6 with 18-150mm lens
I use mine throughout the range at whatever F stop is necessary to get the shot and never concern myself with  sweet spots . That said anywhere between F/5.6 and F/11 will probably be optimal .
KEG
KEG Veteran Member • Posts: 4,909
f/8.
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
Larry Rexley Senior Member • Posts: 1,238
My copy is very slightly decentered, and at the 18mm end of the zoom is noticeably softer in the lower right side until about f5.  Unless lighting is very low I shoot at f5 or smaller. At the long end it's good at f6.3 but slightly better at f8.
I'd say the sweet spot is f5.6-8 as others mention.
The sweet spot seems to be f5.6-8 for most vintage lenses and zooms I've owned, when used on the M6ii or M200 (24 MP sensor like the M6).
I've found modern primes such as the EF-M 22mm f2, Sigma 16mm and 56mm f1.4, Laowa 9mm f2.8, and Rokinons, unlike many vintage primes, can be very sharp up to around one stop smaller opening than their max aperture, and still quite good wide open.   The Canon 32mm f1.4 is exceptional and very sharp wide open.
 Larry Rexley's gear list:Larry Rexley's gear list
Canon EOS M6 II Canon EOS M200 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +21 more
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,481
In the center the 18-150mm is actually sharp wide open at all focal lengths and does not improve that much when stopped down.
For improved sharpness in the corner it is good to stop down to f8.
F11 is the smallest aperture I would for DOF, because defraction is kicking in and softens the image.
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
Ian Abrahamson
OP Ian Abrahamson Regular Member • Posts: 460
Thank you all, i also seem to think the F8 is the safest bet with the lens specifically for that purpose.
