18-55 EF-S Variations Optically
Scott Pickering
Scott Pickering Contributing Member • Posts: 508
There are quite a few versions of Canon's EF-S 18-55 lens. I have 3 of them for various Canons. Other than the later versions have IS, are there any real optical differences between them, especially when the megapixels kept going higher?
 Scott Pickering's gear list:Scott Pickering's gear list
Canon EOS R7 Fujifilm X-H2 Canon EF 24mm f/2.8 Canon EF 50mm F1.4 USM Canon EF-S 18-55mm f/3.5-5.6 IS +9 more
Aoi Usagi Veteran Member • Posts: 3,221
Re: 18-55 EF-S Variations Optically
Optically the later STM version are the best in terms of Image quality. But autofocus speed, autofocus quietness and IS system is also better.  They also have the benefit of having a non-rotating front element, which is good for photographers who use polarizing filters.
If you want to see the difference in optical designs, you can head over to Canon's Lens Hall , and compare the different versions.
