how do you manually adjust the exposure correction
AshleyMC Senior Member • Posts: 2,228
Re: how do you manually adjust the exposure correction
stevet1 wrote:
For myself, about 95% of the time, I shoot in Av mode, selecting the depth of field I want and knowing that the camera is going to automatically select a shutter speed approximately twice what my focal length is. Most of the time that will satisfy any camera shake issues.
I mostly shoot static subjects.
Yes, Av mode is my default mode when shooting general scenes with static subjects.
In such cases, aperture (determining depth of field) is key — the other two can be flexible.
If I “care” only about aperture, I use Av mode.
If I “care” about both aperture and shutter speed, I use M mode with Auto ISO.
Now, I want to add one more item to the mix: Auto ISO with Minimum Shutter Speed.
Revisting what I said about Av mode, I usually let the camera choose ISO and shutter speed but with a restriction: not slower than what I consider the slowest acceptable speed.
In Av mode, I can set f/1.8 plus Auto ISO with minimum shutter speed of 1/100 sec.
The camera chooses to shoot at f/1.8 + 1/125 sec + ISO 100.
Now, as I move closer to the subject, I want to maintain roughly the same depth of field by dialing the aperture down to f/4.5.
The camera chooses to shoot at f/4.5 + 1/160 sec + ISO 250.
In both cases, the camera respects my wish of not shuttering slower than 1/100 sec.
guinness2
guinness2 Veteran Member • Posts: 4,617
Do you limit the Auto ISO from the upper side ? Which camera do you use ?
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
The camera provides the option to set upper limit for ISO. These days, I personally don’t worry too much about high ISO levels.
I use Canon 80D.
Canon 80D Instruction Manual, pages 152-153
guinness2
Re: how do you manually adjust the exposure correctiont
@Digirame wrote:
Yes, shutter speed and aperture are to be fixed if there's motion and the desire to maintain a certain depth of field. The adjustment of the exposure compensation is to make things brighter or darker than what the camera determines.
For example, when I took pictures of some wood ducks I wanted a certain depth of field. With a telephoto lens that is often not easy. So if there's two ducks, then I try to focus in between with the F-stop that I choose. I have to have a certain shutter speed to freeze the action. The ducks may travel in and out of the shadows of trees. The sun may come and go. That's why you'll see a lot of my photos with an ISO6400 or higher. My eyes don't perceive it's that dark, but the camera does. If I don't have the proper shutter speed, the ducks are blurry. If the depth of field is not good, then the ducks are soft or blurry.
It's the same at people events. Things can happen crazy fast, like you don't have time to even think, but you have to make those decisions quickly. With autoISO you don't have to worry about the changing light conditions.
R2D2 who now owns Canon mirrorless cameras told me one time that he sets manually all three settings. Those are the aperture, shutter speed and ISO levels. I tried that a few times at people events, when I knew the lighting conditions were constant.
Do you take pictures of wildlife or people events where there is a lot of motion? Do you use a telephoto lens? With a telephoto lens with a large focal length, there's times the depth of field is very narrow...sometimes only inches.
Yes, I tried all you mentioned. Av or Tv was enough for it. Next time I try your technique. Thanks for the inspiration.
The biggest challenge IMHO are “ Birds in Flight” . It needs a quick focusing lens and sunny day to achieve the optimal SS. DoF is not a big issue here, I guess.
Canon EOS Rebel SL3
DoF must be explictly controlled.
How the bird is rendered — either the head is mainly in focus, or most of the bird is in focus — must be the photographer’s explicit and deliberate decision.
Well, if the bird is about 1/10 or 1/25 of the total frame, nothing is to be talked about.
For birds, I personally use Av mode at f/8 and Auto ISO with minimum shutter speed of 1/500 sec (perching) or 1/1000 sec (in flight).
guinness2
Thanks, I respect your experience, probably more fresh than mine.
As I have not an access to most of my pics, could you estimate the distance you shoot BIF at?
How much of a frame the bird fills in ?
I tried to simulate it on the dofmaster for 5.6, FL 200mm and focusing distance of 10m (APS-C) and the DoF is about 0,5 m , half in back,half in front.
Again, I don’t call your experience into question, but I don’t remember to have any problem with DoF, but with the shutter speed due to dim light and poor AF speed of my lens.
My only safari is feeding ducks on our close city river :-))
Canon EOS Rebel SL3
Count on your own practical experience and artistic preference.
Having problems with the shutter speed due to dim light and poor AF speed of your lens?
Choose the light — move on if you consider the light too dim.
Set the minimum shutter speed — assuming your camera supports such capability.
Poor AF of lens? Actually AF speed and accuracy depend on the lens and the processor, plus integrated assistance by the sensor. In general, high-end cameras such as 80D, 90D, 7D, 7D Mark II (and Nikon D500) are significantly helpful for BIF photography, especially in real-time AF tracking.
Ducks on nearby river or lake?
640mm (EFL), f/8, 1/500s, ISO 800
guinness2
Excellent portrait ! Challenge accepted :-)))
Pretty Angry Beard https://www.angrybirds.com
More tomorrow, when I am on my computer.
Canon EOS Rebel SL3
