X-H2S - any issue with using just SD cards (256GB)
canonbcguy Contributing Member • Posts: 821
I have had great luck using a couple of brands of medium quality 256GB SD cards, 70MB/sec read/write speed in my X-H1 and X-T2.
If I upgrade to an X-H2S, will I have any issues with continuing to use these until the CF Express cards come down in price?
I am just a stills photographer.  No video usage.
The only issue I've had with the SD cards is that occasionally, I will run out of buffer space on the X-H1 or X-T2 and so shooting speeds slow to a crawl.
My understanding is that there is now a huge buffer with the X-H2S and so this should not be a problem.  Is this right?
Are there over 100 shots of JPG+RAW that I can shoot before I fill the buffer on an X-H2S?  If that's the case, I won't run out.
 canonbcguy's gear list:canonbcguy's gear list
Sony RX100 III Nikon D750 Fujifilm X-T10 Fujifilm X-T2 Fujifilm X-H1 +38 more
Fujifilm X-H1 Fujifilm X-T2
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
Re: X-H2S - any issue with using just SD cards (256GB)
You are right - if you don’t shoot long bursts and are happy to maybe wait a while between bursts (and don’t need the extra read speed when transferring images to the computer) this will work.
But - a big advantage of the X-H2S is the speed and when you start shooting at 30-40 frames a second you will be surprised how many images you generate.
70MB/sec sounds like average performance UHS-I cards - they certainly won’t be on the compatible list.
Maybe start with those cards and see how quickly you get frustrated by their performance
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
OP canonbcguy Contributing Member • Posts: 821
Not being a birder or into sports or auto racing, I won't be shooting 30-40 fps bursts. What I do shoot is impromptu portraits and I'm used to shooting at Continuous Low at 4fps. With (I think) only about 25 shots on an X-T2 before the buffer filled, I did fill it often enough to find it annoying.
With the X-H2S and its much bigger buffer, I'm thinking I'd be fine.
The only worry I have is with weird lockups or other issues. I might even increase the FPS a bit to 6 (if that is possible) to ensure I capture the perfect expression.
Morris0
Morris0 Forum Pro • Posts: 32,181
I agree with this though when you put a bunch of frames in the buffer it's going to take a long time to clear the buffer and this is when it could be an issue.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Greybeard2017
I've tried testing with really old slow cards out of curiosity and have seen glitches where  files gets corrupted during a long fast burst. These are slower cards than you have but I'd recommend thorough testing before you risk the cards on an important shoot.
RobRoy22 Regular Member • Posts: 273
You are planning on buying a top-flight camera with a significant price tag and are seemingly unwilling to invest in either CF Express cards or the highest speed SD cards which are best suited to its capability. Interesting choice.
 RobRoy22's gear list:RobRoy22's gear list
Fujifilm X100V Fujifilm X-T5
Alan Hewitt Photo
Alan Hewitt Photo Contributing Member • Posts: 909
I only use SD cards for stills and I've never had an issue when using burst mode and pre-shot etc. That said, I rarely use burst mode for more than a second or so anyway.
Freelance wildlife photographer, filmmaker, photography safari & workshop guide, writer.
INSTA1: alanhewittphoto
INSTA2: bts_alanhewittphoto
 Alan Hewitt Photo's gear list:Alan Hewitt Photo's gear list
Fujifilm X-T2 Fujifilm X-H1 Fujifilm X-H2S Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 50-140mm F2.8 +2 more
What speed of card do you use Alan?
Alan Hewitt Photo
I'm not very technical with it so I couldn't really tell you what all of the numbers mean. I do know it is a pretty fast card though (that's as technical as I often get!), a lot quicker than the OP's anyway.
I have these in 64gb and 128gb....
I just tested one and it took 186 lossless compressed raws at 40 fps before it began to slow on the shutter.
Flying Fijian Senior Member • Posts: 1,623
I use the Angelbird 512GB AV PRO CFexpress 2.0 Type B SE Memory Card with my XH2s...great for the price!
 Flying Fijian's gear list:Flying Fijian's gear list
Ricoh GR III Fujifilm X-E3 Fujifilm X-T4 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R +13 more
Alan Hewitt Photo
You would probably benefit from a quicker card but I don't think you need to spend a great amount of money based upon how you describe your photography.
baobob
baobob Forum Pro • Posts: 18,248
There is no a priori any obstacle to use only a Sd card with the XH2 family. Their buffer is huge for photography, and with a  633x card photo at 40fps is ok
In video you will be imited to some formats and to some settings due to th slow speed of the card, but for simple footages it does work ok
Tha said I would strongly recommend you spare some $$$, watch prices and find aCF E type card at a reasonable price which is now possible
Bob
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
johnCam Regular Member • Posts: 265
I agree with baobab.  I had slower sd cards when I upgraded to the x-h2s.  CFExpress card prices seemed too high, but I chose one with less capacity from a brand I had heard of.  Now I don’t have to think about it.
 johnCam's gear list:johnCam's gear list
Fujifilm X-H2S Fujifilm XF 18-55mm F2.8-4 R LM OIS Olympus OM-D E-M5 Olympus M.Zuiko Digital 25mm F1.8 Tamron 150-500mm F5-6.7 Di III VC VXD
Lentille Forum Member • Posts: 54
Hi going back to your original post question
There is no issue with just using sd card
The x-h2 cameras have huge buffers - 5Gb
So for the shooting you described the buffer in combination with your existing sd cards will be just fine
And as noted in your original post you can upgrade to cfx when the prices reduce further
Your thinking was 100% correct
 Lentille's gear list:Lentille's gear list
Sony RX100 II Nikon D7000 Fujifilm X-A7 Fujifilm X-S10 Fujifilm X-H2 +24 more
Perfect.  You have removed another obstacle from going forward with the X-H2S.
Bob
I suspect that sooner than I think, I'd upgrade if the prices do come down or a decent card is available at a good price now.
The only hangup I currently have with SD cards is that if I shoot a burst and then turn off the camera (currently an X-H1), the camera will dutifully write out the buffer to the SD card before fully turning itself off.  This is normally fine.
There have been times though when, immediately after turning off the camera, another opportunity comes up.  If I then turn on the camera, nothing will happen until the buffer is completely written out to the SD card at which time the camera will then turn off.   I then have to fire it back up before being able to take photos again. This could take a while.
It's annoying because if I had NOT turned off the camera after the initial burst, the X-H1 would be able to continue to take shots, even in burst mode, using any free buffer space that was available.
With a bigger buffer comes the potential for a greater amount of annoyance.
With a near-full buffer, 5GB for the X-H2S someone said here, then simple math has it taking as much as 72 seconds to write it all out to a 70MB/sec SD card, likely a bit longer.
Having the X-H2S be stalled for a minute and half could cause me to grit my teeth...
...maybe with it's much better battery life, I won't be reflexively turning it off so much.
