Canon 28mm IS
Barry Reynolds
Barry Reynolds Regular Member • Posts: 243
Canon 28mm IS
I've just bought a Canon 28mm IS and it's very sharp. I've tested the IS and it seems to work better with a bit of movement rather than trying to stand still. Does IS need movement to work? I've shot down to 1/10 so far and its only sharp if I move a little
 Barry Reynolds's gear list:Barry Reynolds's gear list
Canon EOS M6 II Canon EF 85mm F1.8 USM Canon EF 70-200mm F4L USM Canon EF 35mm F2 IS USM Canon EF-M 11-22mm f/4-5.6 IS STM
MAC Forum Pro • Posts: 18,502
Re: Canon 28mm IS
the m6II is known for shutter shock.
switch to e-shutter and repeat tests
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
Barry Reynolds
OP Barry Reynolds Regular Member • Posts: 243
Re: Canon 28mm IS
I use it with the 6D
Re: Canon 28mm IS
doesn't make sense.
you should be able to get sharp shots down to ss 1/4
Canon EF 28mm f/2.8 IS Lens Review (the-digital-picture.com)
Barry Reynolds
Re: Canon 28mm IS
I can if I move a little but if I'm still it doesn't work. Maybe it's why they tell people to turn off IS on a tripod
Re: Canon 28mm IS
test your theory on a tripod with IS on then off
kodakrome
kodakrome Senior Member • Posts: 1,026
Re: Canon 28mm IS
I've used that lens both ways on a tripod - with the IS on and with it off. I see no difference at all in the images. Have never needed to be moving to get sharp shots.
ffabrici Senior Member • Posts: 1,353
Re: Canon 28mm IS
I have the 28 IS and I don’t have any such IS issues.
