No X-T5 option on Camera remote App?
addled New Member • Posts: 13
Hi, apologies for a possible noob question. On the connection setup when one first opens the app there is no option for selecting X-T5
Sharing 2 screen shots illustrating the same
Am i missing something? Could someone point me in the right direction?
TIA
Best,
Aditya
 addled's gear list:addled's gear list
Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XC 35mm F2 Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 18mm F1.4 R LM WR
nightowlnz
nightowlnz Contributing Member • Posts: 518
Re: No X-T5 option on Camera remote App?
I've checked (I'm on an iphone) and the newest cameras are all there.
It looks like you're on Android so might pay to check in the play store and possibly uninstall and reinstall the app and ensure you allow it to have the permissions it prompts for.
 nightowlnz's gear list:nightowlnz's gear list
Fujifilm X-T4 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR
ragbasti Regular Member • Posts: 321
I just added my X-T5 on android, maybe check manually if there is an update you're missing.
If you want to experience the Dunning-Kruger effect first hand, then just join a forum debate about photography.
 ragbasti's gear list:ragbasti's gear list
Fujifilm X-T2 Fujifilm X-T5 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +2 more
GMacF Contributing Member • Posts: 999
Definitely on my iPhone app.
 GMacF's gear list:GMacF's gear list
Fujifilm X-E3 Fujifilm X-H2S Fujifilm X-T5 Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +9 more
OP addled New Member • Posts: 13
Hi, thanks for the replies. I've uninstalled and reinstalled again. Repeatedly. Also used the QR code on my camera to arrive at the link and tried againI
It's also definitely the latest Apk for the app.
Still no X-T5 option.
Finally selected X-t4 and the camera connected. Not being able to update the firmware because maybe it's looking up the X-T4 (?) (There is a new firmware update for the X-t5)
I'm on Firmware Ver 1.00 and an update exists (Ver 1.01)
I'm on Android. Could i request someone let me know the app version?
I'll cross check with mine.
Bit if a reach and probably a dumb question but I'm stumped so here goes...I'm in India does that make a difference as to which apk is available to me on the app Store??
superspartan
superspartan Regular Member • Posts: 152
TIA
Best,
Aditya
I have a Pixel 7 Pro on Android 13 and it's there
 superspartan's gear list:superspartan's gear list
Fujifilm X-H2S Fujifilm XF 16-80mm F4 Fujifilm XF 33mm F1.4 R LM WR
TIA
Best,
Aditya
Hi, thanks so much for the details. I have the same app build as well.
I'll be trying an apk download of the app from an external source other than the Play Store. Hopefully that helps.
Fingers crossed.
Else I'll just continue as is (via connecting by choosing X-t4) and do my firmware upgrades manually as needed
superspartan
TIA
Best,
Aditya
Fingers crossed.
are you sure you are selecting "cameras with interchangeable lens" and scrolling down?
Yes..
I'm truly baffled. This is just so strange.
Have written to Fujifilm. Let's see what the have to say..
Mandersong
Mandersong New Member • Posts: 1
I'm also having this problem:
Using a Samsung S22 Ultra, android 13
Version 4.6.1(Build:4.6.1.2)
Eventually the X-T5, X-TH2s and X-H2 appeared.
Here was the process to unlock it.
Uninstalled the app, several times.
Rebooted between installs.
Cleared cache before and after each install.
And after the 3rd install, after backing out and back into the app they showed up as options.
*Throws hands up in the air* There was absolutely no reason why it suddenly worked.
If this app functioned at all well I would recommend Fujifilm to more people. But most the people I know need workflow to go through their phones. I don't want to bring a laptop everywhere when I have a perfectly good phone. What's the point of being low weight if you have to bring other equipment?!
 Mandersong's gear list:Mandersong's gear list
Fujifilm X-T30 Fujifilm 50-230mm II Fujifilm 50mm F2 R WR 7artisans 55mm F1.4 Fujifilm 15-45mm F3.5-5.6 OIS PZ +3 more
Aurobindo Saha
Aurobindo Saha Senior Member • Posts: 1,576
I faced the same problem, after quiting the app, and clearing the cache, suddenly "by some miracle" I could bsee X-T5 and other newer models. Except for GPS location tagging, I do not find any good use of that app in my case.
Regards
Aurobindo
I love photography - I love painting canvas with light
JerryLi New Member • Posts: 1
I have the same question.Try to reinstall the APP, re connnect the phone weith it.
