x-e2 upgrade
merapi Junior Member • Posts: 26
x-e2 upgrade
Hi,
I have been using x-e2 for several years and I would like to upgrade a bit. I use it for landscape photography, low light (blue hour) and partly street and family pictures. I am not a profi photographer. What would you recommend, please? What about x-s10?
Thanks a lot
Richard
https://500px.com/merapi
Fujifilm X-E2
britcam
britcam Senior Member • Posts: 2,583
Re: x-e2 upgrade
merapi wrote:
Hi,
Thanks a lot
Richard
I had my X-E2 in 2014, along with the 18-55 kit lens ... and soon after, I bought the excellent 55-200 and the 10-24. Those three lenses served me very well until last year, when I thought the time had come to think about an upgrade.  IBIS was very tempting for shooting in low evening light, and for using a few primes such as the 60 macro and 35 f1.4.
I went for a very mint used X-H1, and loved it, but in the end I valued the X-E2 for it's compactness and light weight, so bought an X-S10, again in absolutely mint condition, with roughly 5000 clicks.  In comparing the two, I became attuned to the X-S10, and sold the X-H1. Since then I have thoroughly enjoyed the X-S10 and it's has become almost second nature, much as the XE-2 had become.  Physically, It's about the same length as the E-2, but the grip means that it can easily be carried on one hand ..
It has of course all the film simulations, and I'm still experimenting with those, plus I've never completely used up a battery ..  I had thought about an X-E4, but at more than twice the price, and with far more weight, there didn't seem any benefit for my usage. On the question of its swivel screen versus a tilt screen of say the X-T2, I'm getting more and more used to the benefits of the swivel screen - especially low camera angles in portrait mode ...
Regards
Rich S
 britcam's gear list:britcam's gear list
Fujifilm X-E2 Fujifilm X-M1 Fujifilm X-S10 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +8 more
OP merapi Junior Member • Posts: 26
Re: x-e2 upgrade
Hi,
Thanks a lot. I also use 10-24, don´t have long lense. I would appreciate also vlogging use of x-s10. I dont use film simulation, because I do RAW shooting and post processing. Thanks.
io_bg
io_bg Senior Member • Posts: 1,548
Re: x-e2 upgrade
merapi wrote:
Hi,
Thanks a lot
Richard
The upgrade from X-trans II camera to X-trans 4 will feel like a day and night difference. The camera will start faster, focus faster (and better) and will feel more responsive overall. You won't regret it. However, the X-S10 has a different control layout and lacks the usual Fuji dials, so keep this in mind if you're a Fuji dial lover.
Best,
Yoan
 io_bg's gear list:io_bg's gear list
Fujifilm X-T30 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +4 more
Re: x-e2 upgrade
Thank you,
What I would like to have is exposure compensation, but it should be on back dial. More and more turning to the x-s10. Thanks.
britcam
Re: x-e2 upgrade
merapi wrote:
Thank you,
Yes, the exposure comp dial is on the rear corner thumb dial, but as with ISO settings, it's not marked. However, very quickly you do adapt & get used to using the screen to view settings ...
Regards
Rich S
Ringwraith69
Ringwraith69 Veteran Member • Posts: 3,407
Re: x-e2 upgrade
merapi wrote:
Hi,
Thanks a lot
Richard
Hi Richard,
Just wondering: what exactly do you feel should be 'better' in your next camera. Where do you feel the need for an upgrade?
The rangefinder-style of the X-E series with their specific user interface is very hands on, very much aimed at giving as direct as possible control over all photographic parameters. If you like that style of camera and want to stay with that, upgrading to a newer model in the X-E range (like the X-E3 or X-E4) or maybe even an X-Pro2 or X-Pro3 would be the logical option.
If you're just looking for a newer generation Fuji camera with generally updated features, a compact and well handling body and a reasonable price point, but missing the more direct control isn't a deal breaker, I'd certainly go for the X-S10.
Good luck in deciding!
(We are only immortal for a limited time)
 Ringwraith69's gear list:Ringwraith69's gear list
Sigma DP1 Fujifilm FinePix X100 Fujifilm X-S1 Sony RX10 II Sony RX10 IV +42 more
Katzen Muscony Regular Member • Posts: 123
Re: x-e2 upgrade
merapi wrote:
Hi,
Thanks a lot
Richard
X-T5
 Katzen Muscony's gear list:Katzen Muscony's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T1
Re: x-e2 upgrade
Hi, easier question? What could be better - faster zooming, faster saving, it should have a grip, stabilisation (I like low light) and build-in flash (I even tilt head of flash in my x-e2 by fingers and bounce the light). Low rating of x-s10 for landscape photography is probably due to missing weather sealing. I like windy, rainy weather, but short time should be OK. Sure, direct control is nice with X-E2.
X-E3 - almost like x-e2, 5 years old
X-E4 - nice, but missing what I want
X-pro3 is much more expensive
X-T5 as someone suggested, again out of my budget.
Thanks a lot!
Singingsnapper Regular Member • Posts: 273
Re: x-e2 upgrade
You can get a grip for the XE4 if you want a grip.  I Part ex'd my XE4 with grip and thumb rest for the XT5.  I use it like PASM (heresy in these parts, I know, but I tried the XH2 and the grip didn't feel as good to me.
 Singingsnapper's gear list:Singingsnapper's gear list
Sony RX100 VII Sony a6000 Fujifilm GFX 100S Fujifilm X-T5 Fujifilm XF 35mm F1.4 R +7 more
