Another light painted still life
imnotmarvin
imnotmarvin Regular Member • Posts: 330
16
 imnotmarvin's gear list:imnotmarvin's gear list
Fujifilm XQ1 Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS +2 more
Marlin Roberts Regular Member • Posts: 371
Re: Another light painted still life
This looks incredible. I have wanted to do a series of shots of my old photo equipment collection and this is a really interesting technique/look. I will see about giving it a try...
 Marlin Roberts's gear list:Marlin Roberts's gear list
Nikon D2X Nikon D610 Nikon Z6 II Nikon Z9 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +12 more
meow
meow Veteran Member • Posts: 5,752
Looks really good. Fantastic light one wouldn't guess comes from a flashlight.
I liked your previous light painting too. It actually inspired me to try. Didn't bother with arrangements, just put a low basket with fruit on a black T-shirt (the only dark fabric I had around). But the light came out great even if it was my first try. I've wondered how to accomplish this kind of light and now I know - a flashlight. I'll definitely try to get more skilled at this. Just need to get some props.
 meow's gear list:meow's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Venus Laowa 7.5mm F2 MFT 7artisans 7.5mm F2.8 Fisheye +2 more
newmikey Veteran Member • Posts: 5,202
That almost looks
like a Dutch Master 17th century work due to the lichting. Absolutely stunning!
 newmikey's gear list:newmikey's gear list
Pentax KP Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 85mm F1.4 EX DG HSM Pentax 16-85mm F3.5-5.6 WR +2 more
T bird
T bird Contributing Member • Posts: 582
Super nice work.  I love doing light painting but I have not achieved anything this nice.
Hornsbee Regular Member • Posts: 418
imnotmarvin wrote:
Very well done!
 Hornsbee's gear list:Hornsbee's gear list
Panasonic Lumix DMC-LX7 Olympus OM-D E-M1X
philzucker
philzucker Forum Pro • Posts: 10,390
Beautiful indeed, I have to second all the other comments here. Did you use any special kind of torchlight for the light painting? E.g. did you use different wide and narrow beams and strengths of light for individual "light strokes"?
Thanks for sharing!
Phil
imnotmarvin
OP imnotmarvin Regular Member • Posts: 330
Thanks for sharing!
Phil
Thank you. I used a Coast G20 inspection light (shown in the photo below) although it's probably not super critical to use an inspection light. The inspection light has a very defined circle of light that I thought might have some advantage but I've made modifiers for the flash light that negate the tight circle. The modifiers in the photo from left to right are a small diffuser, a large diffuser and a pseduo light brush. The diffuser is basically just a tube made from poster board with a couple layers of scotch tape over the end, gives a soft but somewhat focused light. The large diffuser is a 3/4" PVC elbow with 3/4 to 1/2 reducer and a sleeve for fitting on the light made out of poster board. The pseudo brush is poster board flattened out on the exit side. I can paint a strip of light across an image with that. Editing an image now that I employed that tool.
I find the large diffuser is great for working soft light into areas of the photo and the small diffuser is great for adding highlights.
philzucker
imnotmarvin wrote:
Thanks for sharing!
Phil
You made most interesting tools here. Thanks for sharing the info! You certainly are an accomplished and inventive light painter, kudos!
Phil
