Filter for protection…?
BrianOdell Forum Member • Posts: 96
I have a “carry-everywhere” m200 that I’ve been using a lot lately with the 22 & 32mm lenses. Should I be using protective UV filters, or skip them? If yes, which brands are decent that won’t degrade image quality, and that won’t break the bank?
Thanks!
Pentax Optio M20
nnowak Veteran Member • Posts: 9,076
Re: Filter for protection…?
Thanks!
Skip them.  They will do nothing to improve your photos, but even the best have the potential to degrade you photos.  If you want to protect you lenses, and also improve the image quality, always use a hood on your lenses.
The only times you would want to use a protective filter is in extreme situations like the Sahara during a sandstorm or macro photos of a welding arc.  For typical day to day bumps and dings, they are pointless.
Larry Rexley Senior Member • Posts: 1,238
nnowak wrote:
Thanks!
I agree with this, although from time to time you still see posts and videos urging you to always use a filter. Perhaps from YouTubers who get paid to refer people to equipment purchasing links! I find that even the best filters add a little flare and unwanted reflections when night shooting.
I use step-up rings on most lenses that are smaller than 55mm filter size, which also helps provide some protection from lens-front 'dings' and stray fingers hitting the front element.  I do this partly so that I can use 55mm filters on the lenses with less hassle. The lenses I've stepped up are the Canon EF-M 22, 32, 15-45, and 18-55. I don't use one on the EF-M 55-200 because the lens hood won't come on or off with a step-up ring on it.
For the EF-M 18-150mm, which already has a 55mm filter size, I add an 'empty' 55mm filter from which the glass has been removed ---- the glass on this lens is very close to the front, quite exposed --- I find I hit it with my fingers and the lens cap too often and this extra protection really helps. The lens hood still fits fine on it with a 55mm filter.
 Larry Rexley's gear list:Larry Rexley's gear list
Canon EOS M6 II Canon EOS M200 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +21 more
Dareshooter Veteran Member • Posts: 5,842
I’m a bit clumsy and sometimes get finger marks on lenses so for the past thirty years or so I’ve always put a protective filter on. They can however degrade image quality if the lens is shooting into the light for instance so I remove them in that case.
Don’t buy bargain basement filters though as they will degrade image quality at all times not just in the scenario I indicated earlier. The 22mm was my one exception though as the front element is so small that even a muppet like me would be hard pressed to mess it up so I never used a filter on that one. The little hood that is available for the 22mm will give much better protection than any filter so get that if don’t have one already.
As for brands that won’t break the bank  I always buy Hoya or Marumi and they are of sufficient quality.
SW Anderson Contributing Member • Posts: 549
Thanks!
Super cheap filters are typically "get what you pay for" disappointments. Lensrentals did testing of UV filters awhile back and found a somewhat pricey Hoya model to be best-in-class, truly excellent. (Hoya UV filters are available in cheap, medium and pricey models, so if you're a purist search for Lensrentals and UV filter test to learn which one scored so well.)
I've found mid-priced Waka and K&F UV filters to be well made, multicoated and very good at cutting through haze, rendering skies with some clouds nicely and not degrading images. I have a couple of Hoya and Amazon Basic filters that are decent, as well. Protection-wise, use of a lens hood is an excellent idea. Having a filter in front of the lens provides some additional protection.
If you really, really want the ne plus ultra of image quality, get yourself a top-rated medium-format camera with a collection of lenses whose total price outweighs the annual budget of a few third-world countries, and go for it. Anything less is just fooling around, OK?
If you plan on having many of your images made into highest-quality, giant-sized prints, no sense compromising IQ with with a UV filter -- or for that matter shooting with a dinky APS-C camera. The way to uncompromising IQ perfection is clear. If your photographic aspirations are more down to Earth, use of a decent-grade UV filter is unlikely to cause you or others to turn away from your images in disgust over how icky they look. At least, that's been my experience.
 SW Anderson's gear list:SW Anderson's gear list
Canon EOS Rebel SL1 Fujifilm X-E2S Canon EOS M5 Canon EOS Rebel SL2 Canon EOS M50 +3 more
Photoclever Regular Member • Posts: 253
Thanks!
I use top tier Hoya UV filters on almost all of my lenses. The naming for their top tier has changed over the years. It used to be S-HMC, now it's HD3. A hood cannot protect your front element from sand, rain, spilled liquids, etc. And over the years I have ended up with small scratches on filters that otherwise would have been on front elements. Filters are also necessary to complete weather sealing on several (not all) Canon L lenses. If you never shoot in harsh conditions you will probably get away with not using protective filters. I shoot in harsh conditions.
The one lens I don't have filter protection on is the EF-M 22mm since the filter is such a large fraction of the lens price. And I never shoot my M+22mm in harsh conditions. If I owned the 32mm, it would likely be protected.
With one exception I have never been able to find any image degradation. That includes looking for it (testing on/off under an array of test conditions). And taking the filter off in the field when I suspected it of causing a problem, only to discover nothing changed. (Think night shots with many in frame and off axis point light sources causing flare.)
The one exception was an individual HD3 filter shooting into the sunset on my 16-35 f/4L IS which resulted in extra flare. But I could not reproduce the effect with other filters. That one event caused me to retest all my lens/filter combos and find nothing else. I meant to follow up with Hoya at the time but never got around to it. I've shot with enough of their filters over the years that I suppose one bad one had to get through QC.
istscott
istscott Regular Member • Posts: 467
Thanks!
With the inner focus barrel design of those two lenses, I don't think they would benefit much from the protection aspect. If the hit is strong enough to damage glass then it will likely destroy the autofocus function too. With the 32mm lens you are better off buying Canon's official hood which connects to the dedicated hood rails instead of the inner barrel's filter threading.
That said, I personally use average multi-coated filters on my lenses out of pure convenience except when testing lenses. I don't use lens caps. Like someone else said, it's pretty easy to accidently touch the front element with a finger. With a filter on most of the time I never have to clean the front element of lenses and when cleaning the filters I don't have to put much care into it. I buy cheaper ones as long as they have a legitimate coating. That said, sometimes in night time or other harsh lighting  situations it's a good idea to remove the filter.
R2D2 Forum Pro • Posts: 26,530
Thanks!
Welcome to the Forum!
Filters are like any other accessory. Use them when the situation calls for it.
If you believe there is risk, put a (high quality) protective filter on. For some people, yes this could mean 100% of the time.  That’s OK.
For me, this is a rarity (only when blowing spray/sand could be an issue). Then I use the highest quality filters I can find (I prefer the B+W MRC varieties), because as mentioned using even the best filters can have an effect on IQ (and using lesser filters can even affect autofocus ie. with telephotos).
Polarizers, ND filters, and special effects filters can be used as needed of course (I also recommend high quality filters here too). And lens hoods are good 100% of the time.
This practice has served me well for quite a few decades now. Knock on wood!
Happy shooting!
R2
Chrisinhouston
Chrisinhouston Contributing Member • Posts: 507
Thanks!
This is an age old difficult question a lot like "Which is the best for computing,  Windows or Apple". People have strong opinions on the topic, some based on experience but a lot are based on what well known photographers have told them or written about.
A few things you might consider are do you go out in dusty conditions? Do you keep your camera and lenses in a bag with dividers so they aren't knocking around and carefully put the lens caps on each time you store them? Do you think you might ever sell your lenses and buy different ones at some point?
I shot professionally from 1976 to 2010 when I retired and I had filters on my cameras almost all the time. Quite often a UV filter but also warming filters, soft focus, Kodak Wratten filters, etc. When I was out shooting an annual report and chasing the light I was lucky to get a rear cap on a lens when I switched out but hardly ever a front cap, I tossed the lens into the bag and moved on to the next shot before the light changed.
Now I am retired but still shoot a lot for myself and I own at last count 24 lenses for 4 different camera systems. Every one of my lenses has a protective filter on it. I sometimes try out a lens and then might sell it if I feel it's not what I want. Small marks on the lens barrel are not a big deal but a scratch on an element makes it worth a lot less. In all my years of shooting I have never had a filter lower the quality of an image but then again I buy the best filters I can afford. B&W, Charo and ones made by Breakthrough Photography. B&H sells these in many sizes or check Amazon. I get the higher end models made of brass instead of aluminum and with Schott glass and a 99% transmission value.
You get what you pay for, good filters don't degrade images but cheap ones could. Also try not to stack filters, you remove the UV when putting on a polarizer. And remove the filter if shooting into the sun or bright lights is generally considered the best thing.
Ultimately only you can decide. For me a $2500 lens is going to have a $100 filter on it. It's like insurance. And you have to wonder if Canon, Nikon, Hasselblad and others would be selling and recommending filters for their lenses if they caused problems.
“Which of my photographs is my favorite? The one I’m going to take tomorrow.” – Imogen Cunningham
 Chrisinhouston's gear list:Chrisinhouston's gear list
Canon EOS 7D Mark II Canon EOS M5 Canon EOS R Canon EOS R7 GoPro Hero5 Black +23 more
