Light painted still life
imnotmarvin
imnotmarvin Regular Member • Posts: 330
7
 imnotmarvin's gear list:imnotmarvin's gear list
Fujifilm XQ1 Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS +2 more
richj20 Forum Pro • Posts: 10,181
Re: Light painted still life
A beautiful composition.
Would you explain your technique?
imnotmarvin
OP imnotmarvin Regular Member • Posts: 330
Thank you Richard. I take multiple exposures (2-3 seconds typically) where I paint a small part of the image with a small flashlight. I'll mix in light from multiple angles and a mix of hard and soft light using the bare flashlight and the flashlight with a homemade diffuser. I stack them all in photoshop and use masks to bring in the parts I want to be part of the final image.
I get asked a lot why I don't use strobes or constant light. One, I enjoy the process of making images the way I do. Two, not as evident in this image but I like to play with subtly surreal light with a mix of hard and soft shadows from multiple directions. I could probably do that with strobes/constant lights over fewer frames but again, I like the process. I'll post another image that's a little more "unnatural".
Very interesting technique. Thanks.
- Richard
Jack Tingle
Jack Tingle Senior Member • Posts: 1,526
Nice photo.
The first time I saw this approach (1980-ish), the plant photographer was to photograph a failed part. The room was dim, & he had one hardware store reflector with a 60 watt bulb. He set his Crown Graphic up on a tripod, clicked the shutter open & danced around like a madman, waving the wide, feeble light source wildly. Except he wasn't. He knew exactly how long he needed to expose, from what direction. His single photo showed the key features perfectly. Not his first rodeo.
 Jack Tingle's gear list:Jack Tingle's gear list
Canon PowerShot SX720 HS Panasonic Lumix DC-ZS70 Olympus OM-D E-M10 II Panasonic G95 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +8 more
imnotmarvin
Nice photo.
Thank you. I feel in love with the work of Harold Ross and decided to give it a try. I've kind of gone in a different direction then him but he's a master.
