M200 sensor dust and what are these white pixels?
StrugglingforLight Regular Member • Posts: 126
Maybe it was a mistake getting the M200 without it's sensor cleaning functionality. Half joking.
Background: The camera is less than a month old and it's been with the kit lens attached since day 1. It's a Canon refurb and I regret not checking the dust situation when it first arrived for a baseline.
But anyway, what are those white pixels that appear in the 200x zoom image? I notice a few of them in the picture. An issue with the camera? TIA.
Sensor Dust at 45mm, f/40, ISO 100, 30s shutter speed
White pixels from zooming into above. Notice quite a few of them.
OP StrugglingforLight Regular Member • Posts: 126
Re: M200 sensor dust and what are these white pixels?
After researching discovered those white pixels are "hot pixels" that occur when doing long exposures. And it's fairly common. Apologies for the dumb thread.
Sittatunga Veteran Member • Posts: 5,406
Not a dumb thread at all.  Canon cameras will map out a lot of those hot pixels if you force a sensor clean from the khaki spanner menu.  I don't think that's possible with the M200 though.
Advi
Advi Regular Member • Posts: 456
Take a picture of a blue sky (or white snow) in order to search for dust on the sensor.
Bye
 Advi's gear list:Advi's gear list
Canon EOS M50 Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM
The only "workaround" I could find for the M200 is turning on noise reduction for long exposure. That only affects the jpg though, I think. In raw, has to be fixed in post.
That is what picture 1 is showing. It's taken of a light colored wall and adjusted in post to bring out the dust more.
It works in RAW too, because the camera takes a second, equally long (dark) exposure with the shutter closed and subtracts that from the original light exposure. That's very noticeable with a 30 second exposure.
