Scotland in October / X100V / XT4+18mm and?
Cossio
Cossio Regular Member • Posts: 154
Fixing to go to Scotland in October for my mothers 80th birthday. We will be there for 14 days. Can anyone share  and recommend some “Must See and Photograph” sites? It will be our first time in that country and we are booking for the tail end of the trip a light house in the northern most part where you can see the Aurora at night. We will probably end up flying into Edinburgh or Glass glow. So any advice that anyone can kindly share I would for ever be great full.
also wondering if my 18mm is wide enough for the landscapes or if I should in get something a little wider. I had a 16mm F2.8 but sold it.  Not looking for anything that is super fancy and expensive. I like to travel light and will be taking my X100V and my XT4 with the 18mm
thinking about investing in a drone for some aerial shots. Thoughts?
 Cossio's gear list:Cossio's gear list
Fujifilm X100V Fujifilm X-T4 XF 90mm Sigma 56mm F1.4 DC DN | C (X-mount) Fujifilm XF 18mm F1.4 R LM WR +3 more
Fujifilm FinePix X100 Fujifilm X10 Leica X1
Dunnie
Dunnie New Member • Posts: 11
Re: Scotland in October / X100V / XT4+18mm and?
I’d recommend Dougie Cunningham’s Photographing Scotland: The Most Beautiful Places to Visit as a great book for inspiration:
https://www.amazon.co.uk/Photographing-Scotland-photo-location-visitor-guidebook/dp/0992905176
I’d also be tempted to take a telephoto if you can, there could be lots of opportunities to pick out details in the mountains and hills.
 Dunnie's gear list:Dunnie's gear list
Fujifilm X100V Fujifilm X-T3 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 50-140mm F2.8 Fujifilm XF 35mm F2 R WR +1 more
bastibe
bastibe Senior Member • Posts: 1,236
Personally, I think the difference between 18 and 23 is too small to be useful. I'd prefer to take a 14 or 16 instead of the 18.
 bastibe's gear list:bastibe's gear list
Ricoh GR III Fujifilm X-Pro2 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +5 more
Rod McD Veteran Member • Posts: 8,589
Hi,
I'll let you do your own research on Scotland.   Great and historic country.  There are wonderful images wherever you turn.
As far as lenses are concerned, it's personal. Your gear list seems to indicate that you've ditched your small portable primes in favor of big fast primes.  Since you already have the fast 18, 33 and 56 in your kit as your preferred lenses (and with the 90/2 being a bit more specialized) why not just take the trio and be done worrying about it?  The only thing I'd add would be a telephoto zoom for longer reach.
I like a small light kit for travel.  Less is more, etc...  I've sold my fast lenses and kept all the small ones - the stuff you've sold off.....:-)  Different folks......etc.
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
a_c_skinner Forum Pro • Posts: 13,047
Falls of Clyde if it has been wet.  The road across Rannoch Moor and Glencoe.  Two that stand out for me.
Travelling light I'd just take the 23mm in the X100.  It is a good lens and if not wide enough you can stitch frames but you do need to practice first.
I've always hankered after a really good drone but that doesn't really add up to travelling light.  You also need a CAA licence I think.
six 24mm X-T2 frames stitched.  Rannoch.  Hand held.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
FujiJon
FujiJon Contributing Member • Posts: 580
For locations: pretty much anywhere on the west coast.  The Isle of Skye (the Quiraing, the Storr, Glen Brittle,  the Cuillins).
Take a good raincoat.
Don't complain about growing old, it's a privilege denied to many.
 FujiJon's gear list:FujiJon's gear list
Fujifilm X-H1 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS Fujifilm 16-55mm F2.8R LM WR Fujifilm 16-50mm F3.5-5.6 II +1 more
sir_c Contributing Member • Posts: 740
Last October I went to Scotland around Aviemore. It was with my company, so there were some private events involved. Outside these obligatory activities there was plenty of opportunity to see things for fun, e.g. Inverness, Loch Ness and Urquhart castle, Cairngorms, Loch Morlich.
Due to tight schedules I mostly used my 16-80 as walkaround lens. Some indoor and late night i used my 35/1.4 and 56/1.2, but only a couple.
Most surprising though was the hike into the Cairngorm mountains I did one morning. I thought that I would be using my UWA a lot, but to my great surprise I shot a great deal with my 50-140. There was so much to see that 50mm felt like a wide angle.
Here is a link to my album with the public photos
https://flic.kr/s/aHBqjAhMVr
Hope it helps
 sir_c's gear list:sir_c's gear list
Fujifilm X-T1 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
mlodge Regular Member • Posts: 189
We typically visit Scotland once a year. I think the 18 will be wide enough. My preference for travel would be the 16-80mm F4, which is a sharp lens giving you a lot more versatility at lower weight than 3 primes, and is great on the X-T4. But I'm guessing that since you don't own any zooms you want to stick to primes!
On the drone front, buying something less than 250g in weight (e.g. the DJI Mini 3/3 Pro, or Autel Nano/Nano+) means you can fly in far more places in the UK. You do need UK CAA (Civil Aviation Authority) registration, but it's cheap and easy to do online.
October weather in Scotland is unpredictable, but tends to be wet and windy. Take appropriate wet weather gear, and a clear shower cap works well as a camera cover. It may significantly limit how much drone flying you will get to do -- you can't fly in the rain, and wind is a problem with <250g drones.
Edinburgh is very photogenic -- the old town, Castle, Holyrood House, Arthur's Seat are all worthwile. We've done a loop North-East out of Edinburgh via Dundee to Aberdeen, then into the Cairngorms to Ballater and then up to Glenlivet / Speyside, following the river to Aviemore. From there you can go West to Inverness / Loch Ness, down to the Trossachs, or back to Edinburgh.
For short day-trips from Ediniburgh, Rosslyn Chapel just outside Edinburgh is very interesting to visit and something you won't see anywhere else, though no photography inside. Sterling Castle is also picturesque. Lots of castles also along the coastline East of Edinburgh if you are into history.
Cossio
OP Cossio Regular Member • Posts: 154
That was all great feedback. I truly appreciate everyones tips & tricks. I hope we manage to get some good days in October. We just finalized the cabin that we will be staying at in the city of Sligachan. It looks to be a center point to many wonderful sites in the isle of Skye.
My X100V will by on me at all times in a water resistant sling from Wandrd. I just picked it up and seems nice and compact and small. Its a 3L but feel I should have gotten the 6L instead.
Im Taking my XT4 with the 18mm F1.4.
If I'm to take a second lens for the XT4 which one do you thing would be better in the city?
  1. The 33mm F1.4
  2. The Sigma 56mm F1.4
  3. The 90mm F2
  4. Alternately leave the X100V at home and just leverage the XT4 with the 3 lens options I mentioned above.
  5. Impulse Option: Purchase a 23mm F.14 lens to use on the XT4 and entirely leave the X100V back in the states
Im an amateur and I can't even begin to think what it's like for a Pro having to decide daily what gear to take.
richhdesign New Member • Posts: 20
We went in September 2021 and it's just a ridiculously pretty place. As mentioned above the west coast from Glencoe up to Skye is just incredible. Your 18mm will be wide enough and your 90mm should be good enough to pick out some good details.
I took a DJI Mini 2 and shot the following along the route. It's under 250g so can fly most places if you're careful.
Decent boots and waterproofs.  Good map.  All the good pictures of the Quirang are taken from higher up.
This was summer 1974, taken on cheap film and through a cheap lens.
Andrew Skinner
Jeff Biscuits Senior Member • Posts: 1,166
  1. The 33mm F1.4
  3. The 90mm F2
Given that you’ve not listed any ultrawide options, and only one telephoto, I’d put another option on the table…
6. Get the two converter lenses and take just the X100V
It’s a perfect city camera and the wide converter will cover the 18mm you’re planning to take. And a 3L sling should be more than enough 🙂
 Jeff Biscuits's gear list:Jeff Biscuits's gear list
Ricoh GR Digital II Ricoh GR Digital IV Fujifilm X20 Fujifilm XF10 Ricoh GR IIIx +14 more
RobRoy22 Regular Member • Posts: 273
The October weather in Scotland is unpredictable. It can be moody and magnificent or just plain wet with low cloud. I am not a drone user but my opinion is there is enough to enjoy in the more rugged and wild parts of Scotland on a first trip from ground level (low or high). Enjoy the views through your lens and with your eyes would be my advice.
BTW when I was last on Skye in October the cloud was so low it wasn’t possible to see the Cuillin Hills and the best option was a visit to the distillery. I had better weather in other places tho’ including a memorable walk up Glen Mullardoch.
Watch out for possible road closures in very wet weather, especially the A83 Rest and Be Thankful route. Have a wonderful trip.
 RobRoy22's gear list:RobRoy22's gear list
Fujifilm X100V Fujifilm X-T5
"especially the A83 Rest and Be Thankful route."
A good point, it seems to spend as long shut as open at times.
Andrew Skinner
Maybe worth emphasising the frequent winter closures are due to landslides rather than flooding. Fabulous route though.
I’ve long thought it would be fun to be ‘caught’ in the alternative convoys along the old military road, but last time we were heading back that way in our motorhome was warned that the waits can be very long so we took the alternative to Dunoon and Clyde ferry instead.
Denver100 Regular Member • Posts: 246
I highly recommend checking out the Isle of Mull, and the village of Plockton area on the west coast. Consider a wide lens and a medium telephoto - perhaps renting the 10-24 WR and the 70-300 WR. Oban is a major western ferry terminal with multiple islands accessible from there. Scotland especially on the west coast will absolutely require WR lenses :-).
Here are a few shots.
Plockton harbor
Edinburgh castle
PS. Edinburg is a street shooters delight!
Caledonian Canal
 Denver100's gear list:Denver100's gear list
Fujifilm XF 16mm F2.8 Fujifilm X-T4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +7 more
