Tamron EF 85mm f1.8 VC on M6 II?
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,481
Hi,
has anyone experience with this lens on M6 II (or any other M body)?
Is it working properly?
Actually I was going to get an EF 100mm F2 but that deal went rotten...
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
Canon EOS M6
Iyou1 Regular Member • Posts: 111
Re: Tamron EF 85mm f1.8 VC on M6 II?
I am sure it will work fine.
However it's best to use it with a full frame body.
thunder storm Forum Pro • Posts: 10,139
Maxmolly7 wrote:
Hi,
I've used that lens on the R. It's a great lens on the R, although the focusing wasn't fast enough for my needs. It could be easily fast enough for your needs.
I think it's save to assume it will work well on the M6II.
45 is more than enough, but 500.000 isn't
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
R2D2 Forum Pro • Posts: 26,528
Is that because of sharpness issues, due to the high resolution (pixel pitch) of the M6ii’s sensor?
R2
MAC Forum Pro • Posts: 18,487
Maxmolly7 wrote:
Hi,
I'd recommend the 100L instead
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
MAC wrote:
Maxmolly7 wrote:
Hi,
That's 160mm in stead of 136mm full frame equivalent. Can be either a good or bad thing.
I expect the Tamron to be sharper at f/2.8, especially at longer distances.
thunder storm wrote:
MAC wrote:
Maxmolly7 wrote:
Hi,
on my m6II, at 7 fps, and dxo PL, the 100L hits focus 7 for 7, and is a dream setup for me with macro capability, portrait capability, and a mfd of 1 foot
if you need shorter, go with the 56 f1.4
Maxmolly7
OP Maxmolly7 Senior Member • Posts: 1,481
MAC wrote:
Maxmolly7 wrote:
Hi,
To late! It is coming..
MAC wrote:
Maxmolly7 wrote:
Hi,
I'm not saying it's bad, I'm just saying the Tamron is sharper at f/2.8. There's also more light available when needed.  Magnification factor is pretty bad admittedly.
That one has no IS.
Maxmolly7 wrote:
MAC wrote:
Maxmolly7 wrote:
Hi,
I had the tamy 45 f1.8 on my dslr's and it wouldn't focus properly, but on my RP it focused fine but I had to turn off the incamera corrections because it gave me weird looking stuff in the viewfinder - once I did that it was fine, but I sold it, and gave away my 50 f1.8 stm, because my m32 f1.4 on m6II  is my 50 fov
the reason I said the 100L is I have no shutter shock and close to 100% hits at 7 fps
best wishes though, it has a good chance for you
Maxmolly7 wrote:
MAC wrote:
Maxmolly7 wrote:
Hi,
Great. Let us know how you like it.
Maxmolly7
MAC wrote:
Maxmolly7 wrote:
MAC wrote:
Maxmolly7 wrote:
Hi,
I will keep you posted.
