Alternative Lenshoods for EF-M 32mm available?
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,481
Hi,
I was wondering if there are "shorter" and perhaps less wide options available from other lenses?
I don't want to add a srew-in typ rubber hood.
Any ideas/options?
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
m100
m100 Senior Member • Posts: 2,048
Re: Alternative Lenshoods for EF-M 32mm available?
Maxmolly7 wrote:
Hi,
Any ideas/options?
Why ?  They push in or out and tilt if needed ?  And can be used to spin a CPL filter ?
Dr. says listen to this every morning.
https://www.youtube.com/watch?v=bEeaS6fuUoA
 m100's gear list:m100's gear list
Canon EOS M6 II
PhotoKhan Forum Pro • Posts: 11,930
Google is your friend.
PK
“Loose praise may feed my ego but constructive criticism advances my skills”
https://www.instagram.com/lisboa_ao_voo_do_passaro/
http://www.humbertoborgesfotografia.com/
http://www.pbase.com/photokhan
(PBase Supporter)
Maxmolly7
OP Maxmolly7 Senior Member • Posts: 1,481
m100 wrote:
Maxmolly7 wrote:
Hi,
Any ideas/options?
Because of the rubber, they do not slip as well into the bag as the plasticky things and they are attached directly to the moving lens element may be causing missalignment when pushed too hard.
It is just a personal preference...
PS: I do get the point with the polfilter though!
Maxmolly7
PK
Of course I tried before, but Google shows me only the ES-60 which I have .
Maxmolly7 wrote:
PK
Ah...!...Sorry...
(PBase Supporter)
m100
Maxmolly7 wrote:
m100 wrote:
Maxmolly7 wrote:
Hi,
Any ideas/options?
Was setting mine up on a tripod and was hurrying, not being careful. The ball head was too loose and the camera swung down and the lens hit hard on a wood table.
Hit on the edge of an installed ND filter.  Both did survive.
Canon EOS M6 II
MyM6II Senior Member • Posts: 2,424
Maxmolly7 wrote:
Hi,
Any ideas/options?
Some people in here are using the hood for the EF-M 18-150mm. I can't remember its name right now. It is shorter, but I don't know about "less wide".
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
MyM6II wrote:
Maxmolly7 wrote:
Hi,
Any ideas/options?
It's EW-60F
lumenite Senior Member • Posts: 1,207
Maxmolly7 wrote:
Hi,
Any ideas/options?
I am using a Chinese one compatible with EW-60F that meets my need.
EW-60F compatible
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
Maxmolly7
MyM6II wrote:
MyM6II wrote:
Maxmolly7 wrote:
Hi,
Any ideas/options?
It's EW-60F
As most EF-M have a 60mm front/barrel diameter, I tried my EW-60F before you wrote but without success.
This morning I tried again, and after a few trials I got to fit! It is really fumbly but it works, great source this forum!
