X-T20 Hot Shoe Flash Not Working
Giantcappuccino
Giantcappuccino Regular Member • Posts: 205
Hello all,
I have been trying to figure out why my X-T20 will not trigger the hot shoe flash. I know that the flash (EF-X8) works on my X-T1, so it's not the flash.
Any suggestions?
(And yes, I tried searching for a past thread first)
Thanks!
 Giantcappuccino's gear list:Giantcappuccino's gear list
Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 23mm F2 R WR
Fujifilm X-T1 Fujifilm X-T2 Fujifilm X-T20
Morris0
Morris0 Forum Pro • Posts: 32,181
Re: X-T20 Hot Shoe Flash Not Working
Giantcappuccino wrote:
Hello all,
Any suggestions?
Thanks!
After mounting the flash, do options in the camera's flash menu become available (Not grayed out)?
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
AndyH44
AndyH44 Veteran Member • Posts: 3,107
Hello all,
Any suggestions?
Thanks!
Morris
Also, you cannot use electronic shutter with flash.
"True craftsmen never blame their tools, but strive to use them properly"
a_c_skinner Forum Pro • Posts: 13,047
Nor if it is on silent IIRC.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Giantcappuccino
OP Giantcappuccino Regular Member • Posts: 205
Hello all,
Any suggestions?
Thanks!
Morris
Hello Morris,
Once the flash is mounted, the only flash menu options not greyed out are Red Eye Removal and TTL-Lock Mode.
Flash Function Setting, LED Light Setting, Master Setting, and CH Setting all remain greyed out.
AndyH44
Hello all,
Any suggestions?
Thanks!
Morris
Hello Morris,
Correction to my previous post: the X-T20 does not have the contact for providing power to the EF-X8 flash. Check the difference between your X-T20 and X-T1 hotshoes.
AndyH44
The Ef-X8 flash isn't on the X-T20 compatibility list. Your "search" was incomplete.
FlashProduct Name (Model Number)CompatibilityNoteShoe mount flash EF-X500✔Shoe mount flash EF-X20✔Shoe mount flash EF-60✔Shoe mount flash EF-42✔Shoe mount flash EF-20✔Wireless Commander EF-W1✔
Giantcappuccino
Hello all,
Any suggestions?
Thanks!
Morris
Hello Morris,
This is the answer 👍
There are 5 points of contact on the X-T1, but only 3 on the X-T20.
I also confirmed by looking at the compatibility list for this little flash on Fuji's website, and it looks like any camera that comes with a built in flash is not compatible, which makes sense.
I was planning on purchasing a Godox flash to do a little macro photography, but was thinking I had an issue with the hotshoe.
Thanks for the help guys!
JNR
JNR Veteran Member • Posts: 4,652
Hello all,
Any suggestions?
Thanks!
Morris
Hello Morris,
You're headed in the right direction. The Godox TT350F is a great match for the X-T20 for macro shooting, and the on-board flash can be used as a controller for it without the limits of direct mounting the flash. Others might recommend larger, heavier flashes, but on the T20 the Godox is a great fit, includes a slide in white card (best for macro shooting) - all at a very good price. Metal foot is a big plus - the flash is built to last.
JNR
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
Giantcappuccino
So, I received a Godox flash today. It works just fine on my X-T20 once I figured out to turn the flash on in the settings 🤣
