Viltrox Adapter - Tripod Mount
BrianOdell Forum Member • Posts: 96
This might be a “silly” question, but… can the screw-on tripod mount be left off of the Viltrox EF-EOS M mount adapter when you’re trying to save space & weight?
nnowak Veteran Member • Posts: 9,076
Re: Viltrox Adapter - Tripod Mount
Yes, absolutely.
istscott
istscott Regular Member • Posts: 467
Do you mean the speed booster or normal adapter? With the speed booster the screw hole opens up into the adapter itself so I'd put tape covering it.
ScentedOrange New Member • Posts: 11
Shouldn’t be a problem, just put it on when mounting it to a tripod because of how much heavier the lens and adapter is compared to the camera. But if you’re using the camera handheld then I’d imagine you’re supporting the lens with your other hand.
 ScentedOrange's gear list:ScentedOrange's gear list
Canon EOS M10 Canon EF-M 22mm f/2 STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EOS 1200D +8 more
Photato
Photato Veteran Member • Posts: 3,152
Yes, but the Viltrox Speed Booster has a different tripod foot that is much harder to remove since you need an Allen wrench to remove two screws.
 Photato's gear list:Photato's gear list
Panasonic LX100 Canon EOS M Canon EOS M6 Canon EOS M6 II Canon EOS R10 +22 more
R2D2 Forum Pro • Posts: 26,530
Exactly the right answer!  Kudos!
R2
