using the phone app to create a focus stack
jim mij Senior Member • Posts: 1,035
hi,
I posted this in the macro forum, but the discovery (for me anyway) of using the phone app to control focus thus allowing a stack to be created was very useful.
One of the annoying limitations of the m6ii means you cannot use the focus stack feature while using the flash, and I needed flash for what I was trying to do as natural light was non existent
I was able to choose my initial focus point, and then use the >> key to nudge focus further into the image and take another picture, repeat that till your stack is complete.
Its a tad slow, but its analogous to using a manual focus rail (if i had one)
It also means i wasn't touching / or nudging the camera between shots
Hope this helps
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
JustUs7 Senior Member • Posts: 4,327
Re: using the phone app to create a focus stack
Hmmm.  Maybe an R isn’t an out of the question upgrade?  🤔
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
ken_in_nh Senior Member • Posts: 2,399
Since alignment is important for decent focus stacks, I always stack with a tripod.  I've not had good luck doing handheld stacks, especially for macro.
With a tripod, I've had natural light exposures as long as 1/4 second, 20 or so images stacked beautifully.  Let me know if you want to see an example.
OP jim mij Senior Member • Posts: 1,035
hi ken, yes this was with a tripod, luckily the spider was resting, but the afternoon light was terrible hence i chose to use flash
I did a stack the other day with 80 shots at 6 secs each, it worked but I wandered off during the capture and after stacking I realised I wasnt happy with the pose... live & learn
Jim
R7 might be a "move across" path for me given my 2 most used lenses are ef-s, but while in camera stacking and better AF are tempting its a lot of £££s for mostly similar results
Jim
