flash for K3
mgolin New Member • Posts: 10
flash for K3
The trusty Metz I've been using for years is no longer behaving nicely. & since it has been a long time, doing web searches, I'm finding several new mfr names that I know nothing about. I'm hoping not to spend $400ish for a Pentax flash, which I'm certain would be fine. I see a Yongnuo that seems fine, but at $85 I feel that I should be nervous. Any experience with this or other 3rd party flashes?
Kobie M-C
Kobie M-C Contributing Member • Posts: 701
Re: flash for K3
Godox/Adorama Flashpoint TT350 p, 860 III p, or V1 P. Those are your best options for your budget.
I am not a Pentax insider. I just have a unique way of gaining insight.
 Kobie M-C's gear list:Kobie M-C's gear list
Pentax K-30 Pentax K-3 Pentax K-3 Mark III Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Pentax smc DA 50mm F1.8 +6 more
kypfer Contributing Member • Posts: 985
Re: flash for K3
I use a couple of Sigma flashguns, specifically the EF-500DG ST PA-PTTL for P-TTL compatibility and an earlier variant of the same model which is TTL only.
I've had no trouble with either, though I've read reports that the foot can be fragile.
The TTL version was bought locally as "new - old stock" for "not a lot" some years ago, the P-TTL gun came from eBay for £5 + p&p
More expensive options are available
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
robgendreau Forum Pro • Posts: 10,926
Re: flash for K3
Yes. I use Flashpoint (Adorama brand slapped on Godox), and it works great. Good prices, and will be compatible with other Godox flash and triggers and such.
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
altis Senior Member • Posts: 1,109
Re: flash for K3
Well out of date - but, none the less, useful:
http://pttl.mattdm.org/
xmeda
xmeda Senior Member • Posts: 1,899
Re: flash for K3
2nd hand AF540FGZ are easily available around $150 and Metz Mecablitz MB 58 AF-2 in similar price level. No need for buying new one.
And concerning behavior, get some isopropyl alcohol, some cloth and wipe contacts on camera. That usually helps a lot.
http://pentax.xf.cz/ - Personal page about my favourite system.
 xmeda's gear list:xmeda's gear list
Casio QV-R40 Casio Exilim EX-Z110 Olympus XZ-1 Pentax X-5 Olympus XZ-2 iHS +42 more
Sjak
Sjak Veteran Member • Posts: 7,318
Re: flash for K3
Agree; and add the Godox Xpro-trigger so the flash can also be used off-camera.
 Sjak's gear list:Sjak's gear list
Leica M Monochrom (Typ 246) Ricoh GR IIIx Pentax K100D Pentax K10D Leica M-Monochrom +1 more
klimbkat
klimbkat Senior Member • Posts: 2,659
Re: flash for K3
I just moved into this sytem and like it a lot. You can get two remote controlled flashes and the controller for the cost of an AF-540, plus, the V1 has some serious power and fast recharge in a 400+ flash dedicated Li-ion battery.
OP mgolin New Member • Posts: 10
Re: flash for K3
Thank yoiu all. FYI I had forgotten about the isopropyl alcohol, & tried it, but same problem. I appreciate the suggestions & will investigate.
Sjak
Re: flash for K3
Myself, I got the TT350P & a trigger. Later I added the AD200Pro as a bigger light.
