R5/R6 Metering
Basil Fawlty
Basil Fawlty Regular Member • Posts: 237
R5/R6 Metering
If I could ask Canon to make one change to the R5/R6 or other R series cameras, it would be to enable a feature that would allow the camera to meter the scene based on where you have the focus point aimed.
I believe how metering works, is say you have spot metering or evaluative metering set - the light for the shot is metered from roughly the center of the scene.  But what if your focus point is somewhere to the left or right and the lighting in that part of the scene is much different?
It would be nice to have a feature (selectable) that would allow you to have the metering based on wherever you have the focus point aimed.  I would think this could be accomplished with a firmware update?
Do you have a "wish" for future firmware upgrades?
 Basil Fawlty's gear list:Basil Fawlty's gear list
Panasonic LX100 Canon EOS 5D Mark IV Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 135mm F2L USM +8 more
PDE94301 Forum Member • Posts: 60
Re: R5/R6 Metering
Although Canon's literature on the inner workings of evaluative metering for R5/R6 is sparse, I believe it does give some additional weighting to the focus point. I don't think it's a true spot meter as the exposure doesn't seem to change massively when moving the focus point from very light to very dark areas. I agree that a true focus-based spot meter would be a nice additional option, as would having a smaller area for the spot metering they do have.  Additionally, I would like to see them add real-time highlights/blinkies pre-capture (as opposed to only being viewable after the shot), and a 14-bit ES mode (even if it's single shot only).
 PDE94301's gear list:PDE94301's gear list
Canon EOS R5 Canon RF 50mm F1.2L USM Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
PMUK
PMUK Senior Member • Posts: 2,999
Re: R5/R6 Metering
Hi Basil,
+ Customise the (Rate) button for other functions and, finally, vary the shots/sec rate in ES.
Phil
Dear Everyone at Canon: Zebras for Stills - How Hard Can It Be?
Basil Fawlty
OP Basil Fawlty Regular Member • Posts: 237
Re: R5/R6 Metering
In a recent video with Canon Technical Advisor Rudy Winston, he is asked about this and confirms that, with the exception of, I think it was the 1DX Mark III, the Canon's spot metering is in the center of the scene when the metering is initiated and is not linked to the focus point.  He further says (paraphrasing) that this is an issue he's heard before and has passed the concern to the product developers at Canon.
SigZero
SigZero Contributing Member • Posts: 686
Re: R5/R6 Metering
Hi Basil,
Phil
Yep, zebra in still is the feature I miss mostly on my R5 (especially after Sony's zebras that were linked to RAW output levels)
As for evaluative metering - for sure it is weighted to current AF region - independently of AF mode of operation.
Br, Pawel
My photo-blog: http://pawel.online
 SigZero's gear list:SigZero's gear list
Canon EOS R5 Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 70-200 F4 L Canon RF 14-35mm F4L IS USM Apple iPhone 13 Pro
drsnoopy Senior Member • Posts: 1,216
Re: R5/R6 Metering
Hi Basil,
Phil
Br, Pawel
The problem with Evaluative metering is exactly that - weighted/linked to the AF point.  This point may not be an appropriate brightness for the rest of the image, leading to incorrect exposure.  One way to avoid this is to use average metering.  Having spot metering tied to the centre of the frame is a nuisance and surely linking the spot to the AF point (portraiture for example) could be implemented in firmware.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
apersson850 Senior Member • Posts: 2,076
Re: R5/R6 Metering
The advantage of evaluative metering is just that - weighted to take the point(s) in focus into more account than the rest. Most photographers tend to focus on the important part in the image, at least most of the time.
Spot metering linked to a focus point is no problem. Just buy a 1-series Canon. The 1DX Mark III is the current camera with this feature. Otherwise aim the center at the point you want to meter, press *, recompose and shoot.
Or use evaluative, as it makes this automatically but easier to handle, since it doesn't go all the way to spot only.
Anders
 apersson850's gear list:apersson850's gear list
Canon EOS 40D Canon EOS 400D Canon EOS 7D Canon EOS-1D X Canon EOS-1D X Mark II +26 more
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
Re: R5/R6 Metering
But it works exactly like this now. See my examples. Both shot at Av, Evaluative metering mode, Spot AF point. No settings changed between the two shots. First image is focused on dark trees in the bottom half of the image. Second shot focused on bright clouds.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
Basil Fawlty
Re: R5/R6 Metering
Sorry, I misspoke in my original post.  Apparently it is only Spot Metering on the R5/R6 (and most other Canon cameras) that doesn't follow the focus point.  Canon Tech advisor Rudy Wilson discusses this in a recent video about Canon AF system. He mentioned it is something that a lot of people have been asking for for a long time and he has, on more than one occasion, mentioned this to the Canon development folks.  After re-listening to that show, I realize it was just spot metering he was talking about.  He did mention that spot metering linked to focus was available in the 1DX Mark III as you mentioned.
I know about metering and recomposing, but it's something I'd like to see as an option on my R5 - the ability to turn on or off spot-metering linked to focus point.  I have been in situations with extreme lighting differences, for example a concert, where metering (spot metering) and recomposing would be impossible as the musician is jumping around.  It's not something that I can't live without but I think it would be nice to have that option.
cfieldgate Regular Member • Posts: 475
Re: R5/R6 Metering
As a long time 1-series shooter, I wasn’t pleased to find out that the R3 doesn’t link spot metering to the focus point 😡. I still bought one though!
 cfieldgate's gear list:cfieldgate's gear list
Canon EOS-1D X Mark II Canon EOS R3 Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 300mm f/2.8L IS II USM +6 more
Distinctly Average Senior Member • Posts: 2,527
Re: R5/R6 Metering
It has only been a thing on top end models for years. I had a film EOS 3 that had this feature, and since then it has been a 1 series only feature. Frustrating marketing decision I fear. These days it is almost certainly not a cost related feature like it was when the metering sensor was separate.
Basil Fawlty
Re: R5/R6 Metering
It seems like such an obvious feature to have and could probably be made available on the R cameras with a simple firmware update.  Yes, you can spot meter and recompose, but in fast moving situations that's impossible.
Re: R5/R6 Metering
With exposure simulation is it as needed as before?
Re: R5/R6 Metering
Multi-spot metering is also something that's omitted from the R3, but a "given" on a 1-series. It appeared for the first time on the T90.
Anders
Basil Fawlty
Re: R5/R6 Metering
I think so, yes.  In some situations, like fast moving concerts with lots of variable lighting, you don't always have time to adjust exposure based on Exposure Simulation.  By the time you think "the exposure on then singer is too dark" and try to adjust some setting to compensate, you have lost the shot.  Being able to have the metering instantly tied to the focus point, I think would be a great option to have.  It's just something I'd like to have available as an option.  Since the 1DX Miii already has this, it's obviously possible.
Abbott Schindler Veteran Member • Posts: 3,099
Re: R5/R6 Metering
I suspect that there’s a reason that only 1-series cameras have this. At the least, it’s a “marketing differentiator.”
Basil Fawlty
Re: R5/R6 Metering
Probably so - but it's still on my wish list. Rudy, in the video I mentioned, said he didn't understand why they didn't include it in the R5/R6/R3.
Re: R5/R6 Metering
They don't want to. As simple as that. They could, for sure, if they did want to.
Perhaps a reason is that for spot metering to follow the AF point there has to be an AF point to follow. The mirrorless are  more about clusters of AF points.
Anders
Sittatunga Veteran Member • Posts: 5,406
Re: R5/R6 Metering
I've always found spot metering to be a great manual exposure technique, so that I can measure the highlights, the shadows and the mid tones and come to a synthesis.  The OM 3 and OM 4 spot meters would even average up to eight readings automatically.  Of course, to do that, you need to find the metering spot every time, which is why Canon put it right in the middle of the screen.  The problem with tieing the spot meter to the focussing point is that focussing works best on a high contrast area which is likely to mislead a spot meter.  Canon's evaluative metering does, in my experience, bias the reading fairly strongly towards the focus spot but not to the exclusion of the rest of the image.  That's what I use for auto exposure with occasional adjustment of the exposure compensation if the exposure simulation looks a bit off.
Atta-Boy Regular Member • Posts: 129
Re: R5/R6 Metering
makes me wonder why mirroless have spot AF modes ? hmmm ... that might be a bug !
