Canon RF 400mm f2.8 vs RF 600mm f4
ajmasterman
ajmasterman New Member • Posts: 6
Hey all,
I tried searching to see if anyone had covered this topic in the forums but hadn't seen anything on this specific topic.
I'm a longtime photography enthusiast beginning to start my side business, and I'm wondering from anyone out there who's used either of these lenses, which is better for sports/wildlife overall: the Canon RF 400mm f/2.8 or the RF 600mm f/4?
With the f2.8, you could obviously put a 1.4x TC on it to turn it into a 560mm f4 to get similar reach with the same max aperture as the 600mm, but I'm not entirely sure if you'll maintain the same sharpness and quickness of the autofocus with the TC attached.
Any thoughts?
 ajmasterman's gear list:ajmasterman's gear list
Canon EOS R5 Sigma 1.4x EX DG Tele Converter Sigma 50mm F1.4 DG HSM | A Sigma 150-600mm F5-6.3 | C Sigma 14-24mm F2.8 DG HSM Art +5 more
Neil Schofield Contributing Member • Posts: 744
Re: Canon RF 400mm f2.8 vs RF 600mm f4
The differences are basically reach with the 600mm and/or teleconverters or one stop faster and greater blur of background with the 400mm at 400mm
You know what you currently shoot and are expecting to be able to shoot upon acquisition so the choice should be a reasonably straight forward one
evertdoorn Regular Member • Posts: 159
I recently acquired the rf 400 2.8 and it’s - as expected - an excellent lens. Also works very well with extenders (autofocus works good). Obviously 600 is better if your subjects require that you always need at least that focal lenght. I actually sold a 500 and went back to a 400 since I’m often quite close to the action, plus having an r5 makes it easier to crop a bit deeper if needed. Either way you’ll end up with a great lens, no matter what you choose
grovep Forum Member • Posts: 59
Not wishing to hijack the thread but does a 400mm f/2.8 with 1.4 TC have the same or better background blur as a 560mm f/4? i.e. does a TC affect depth of field?
KiloHotelphoto Contributing Member • Posts: 770
For wildlife it really depends on what and where you're shooting.  If you are shooting larger mammals that you are able to get closer to like in Africa or bears in Alaska a 400 2.8 maybe more useful.  I was in Botswana last year and took my 600 but I wish I had a 400 2.8 a few times because of the light.
When I bought my first 600 F4 I was looking at the 400 also but because I also shoot a lot of birds and smaller things like chipmunks the 600 made more sense especially when adding the TC's to fill the frame .
 KiloHotelphoto's gear list:KiloHotelphoto's gear list
Canon RF 600mm F4L Canon EOS R5 Canon EOS R3 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +4 more
John Crowe
John Crowe Veteran Member • Posts: 3,476
I photographed with a 400/2.8, and 1.4x, and 2x, for 15 years.  While it was extremely flexible, given my regular shooting situations, if I were to do it again I'd start with the 600/4.  I would take some time to evaluate with your current lenses and typical expected subjects how often a 600mm is too long, and a 400mm too short.
I currently shoot 300/2.8 and 800/5.6, both with teleconverters.  I want something affordable and handholdable in between, so likely the EF 500/4.5 L.  If I find an affordable used EF 600/4 I would likely take it instead.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
If youre are shooting a distant subject with a distracting background or are looking for best subject isolation then I have always been led to believe f2.8 is better than f4 and that the 400mm f2.8 was king of the superteles in that regard, I use a 600mm buts thats for reach
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
SFHR67photo
SFHR67photo Regular Member • Posts: 220
As a retired professional i have one tip for you.  Before spending 12-13,000 dollars on one of these fine lenses, I hope you take the time to rent and evaluate each, on it's own merits.  Your specific shooting style, and a lot of other things will come into play, and you will need to live with your ultimate decision.  If you won't be shooting with it constantly, renting may be the way to go at first.  Anything above 300/2.8 was always borrowed from Canon.
They should both exhibit similar characteristics.
 SFHR67photo's gear list:SFHR67photo's gear list
Sony RX100 III Lytro Illum Fujifilm GFX 50R Fujifilm X-Pro3 Canon EOS R5 +2 more
Tazz93
Tazz93 Veteran Member • Posts: 3,473
I'm in the market for an RF super tele, but neither one has wow'ed me in to a purchase. I was leaning more to the 400 as it is largely a little more versatile with the 2.8, but if you are after birds the 600 is the way to go. If you are mixed, mammals and birds, its a little more tricky.
But ultimately, you have to factor in the type of wildlife and your average location. For example, a Costa Rican birder would likely lean toward a 400 2.8 because they are shooting under a canopy of trees. But for a Californian birder, the 600 wins almost hands down.
Again, I'm waiting for something a little more compelling as I still have an EF 500L II to hold me over. But, to answer the question about performance, most people will not care about the difference in performance between the 400 and 1.4x and the 600, but the 600 is better IQ-wise. AF-wise didn't notice a difference with an R5, but that was a very short sample of the two.
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
