Used Canon batteries from MPB?
m100
m100 Senior Member • Posts: 2,048
Re: Used Canon batteries from MPB?
bgreg wrote:
I have a hard tie believing used batteries is even a topic. After spending hundreds or thousands $$ on camera/lenses -- not springing for a new battery doesn't make it way up there on the bizarre list.
With a 6 month warranty ?
No doubt they get a lot of batteries ?
And factory Canon batteries are first class batteries.
I have used, tested and taken apart enough batteries to know that.
I trust MPB too.  Been dealing with them for years.
Dr. says listen to this every morning.
https://www.youtube.com/watch?v=bEeaS6fuUoA
 m100's gear list:m100's gear list
Canon EOS M6 II
trungtran Senior Member • Posts: 1,747
No warranty on consumables.
I have a crate of Sony, Canon and Nikon batteries that don't work. Even if you don't use them, they degrade over time to the point they won't hold a charge.
$23 for one used OEM battery or you can get 3 NEW third party batteries and a charger. It's a no brainer.
 trungtran's gear list:trungtran's gear list
Olympus OM-D E-M10 Sony a7 II Canon EOS M6
m100
They have a little circuit board in them called a BMS that uses power even when the battery is not being used.
If you let it sit long enough without charging the battery will die and will not recharge.
The BMS will kill the Li-Ion battery in a safe way if it is not used ?
Canon EOS M6 II
geru Senior Member • Posts: 1,409
StrugglingforLight wrote:
geru wrote:
Reading through this thread there are warnings regarding non OEM batteries and while I understand my experience has been very different. The only batteries I've had problems with were OEM batteries and both were Canon.
I've bought non OEM batteries for every camera I've owned beginning in 2007 and never had a single problem. Until recently I purchased only Wasabi brand and they've been very reliable. They seem to last as long as the OEM batteries but I've not actually counted the number of photos for OEM and non OEM.
I was gifted these batteries with charger and I've had no problem with them. If I had to chose a battery that takes more photos it seems to be these. It may have to do with the USB charger which takes much longer to charge then the OEM charger.
Your Amazon link leads to "sorry that Amazon page not found"
Edit: R2D2 beat me to it.
See if this one works. I almost always check links I post but evidently not this one.
This one above works sorry about that.
 geru's gear list:geru's gear list
Canon EF 85mm F1.8 USM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EOS M50 Canon EOS M6 II Canon EF 40mm f/2.8 STM +5 more
