X100 group shot
Miskec Senior Member • Posts: 1,941
X100 group shot
Hi all!
I was asked to take a few quick groupshots of kindergarten kids and their theachers. Total number of people in the photo will be no more than 15.  I will be using only my x100 and i will shoot in the backyard. I am looking for usefull tips.
Time of day to shoot?
Shoot with sun in the background or not?
Shoud I stand on a stool or step to be slightly above them?
Which F number to use?
If people stand in 4 rows, on which row do I focus?
I think built in flash on x100 is too weak?
I am so worried every time I need to take a photo off a group so please help.
Thank you
Fujifilm FinePix X100 Fujifilm X10 Leica X1 Samsung i100
Erik Baumgartner Senior Member • Posts: 6,893
Re: X100 group shot
Miskec wrote:
Hi all!
Any time that there is enough light, but without harsh contrast - definitely avoid midday sun or you're going to have deep shadows to sort in post, best to avoid this. An overcast sky with bright, but diffuse light would be ideal.
Unless you've got a good light source in foreground and/or you want to intentionally blow out the background, I would avoid this.
It might not be a bad idea to minimize shadows, but I'd probably want to keep any peripheral lines in the composition vertical.
It depends on subject distance, but I'd likely go f/5.6 - f/8 for the good sharpness and plenty of DOF.
If I was using AF, probably the second one (there is typically a bit more DOF behind the focus point than in front of it. To be safe, I'd almost certainly flip to MF mode with Focus Peaking on (I like Blue/Low) and dial in the maximum peaking indication for all your subjects (MF operates automatically wide open at f/2 for best critical focus indication, but will shoot at the desired f/5.6-f/8). Avoid standing in too close - better to be at a distance for greater DOF, and a more natural perspective. it's OK to leave a bit of space at the edges and crop a little, 23mm can look a little fishbowly if you're too close.
I really dislike the direct flash look and would likely avoid it even if it wasn't too weak. I'd much rather balance the light in post with a RAW file. I'm sure some folks will tell you to add some fill flash, but it almost never looks better, IMO. YMMV.
Don't worry about it, take a bunch of shots with a bit more and less exposure if you aren't sure. Short bursts are a good idea to (hopefully) get one with everyone's eyes all open at the same time (and the means to fix that if they aren't).
Thank you
No problemo, I'm no portrait expert by any stretch, so take my advice with a grain of salt, but it's what I'd do. Good luck.
Erik
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Night Pixel
Night Pixel Contributing Member • Posts: 976
Check out Kevin Mullins
Mullins shoots documentary weddings with an X100 and XPRO. He has some nice tutorials on shooting groups etc here .
**** REDACTED ****
 Night Pixel's gear list:Night Pixel's gear list
Sony RX10 IV Fujifilm X100V Fujifilm X-H2 Fujifilm XF 80mm F2.8 Macro Tamron 150-500mm F5-6.7 Di III VC VXD +4 more
OP Miskec Senior Member • Posts: 1,941
Re: X100 group shot
Erik Baumgartner wrote:
Sorry for the late response Eric. At the end I did not have to take photos of them,a few had a cold. But your tips came out usefull the next day. I took a few casual shots of my mogher in law and my kids and ive played around with focus and apperture. The shots came out sharp, and since i've used burst shooting i got a few keepers. Oh and I did use the flash. It came out ok.
Thank you once again for the reply.
Neven
Miskec wrote:
Hi all!
Thank you
Erik
Re: Check out Kevin Mullins
Thank you. Mullins is one of best Fujifilm ambassadors. I set up my camera to his recipe.
Neven
a_c_skinner Forum Pro • Posts: 13,047
Re: X100 group shot
When the light is good
Sun behind the photographer
Yes, it will make it look as if you know what you are doing, unless you fall off it.
f8, shutter speed 1/125 or faster.  ISO to suit the light
Four rows might be too much.  You need each row to be a bit higher so I'd go for kids sitting, kids standing, adults behind.  Focus on the middle row
No, it will be spot on, just a bit of fill
Take one adult to the location and practice to get the settings right as if you had a full group.  You can judge the lighting etc with just one person and imagine the rest.
Your real issue will be getting the kids to look at you, behave and so on.  Put one of the teachers to making sure the kids are tidy.  Check surroundings for litter etc.  Check the background carefully on the practice shots.
Get the plan sorted and get the kids arranged quickly and efficiently.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Re: X100 group shot
Ok.
Got it.
I'll better stand on the ground
Thanks.
Got it.
Super, i will try with and without it.
When i will do the actual shoot it will be difficult. It is a kgarten for kids with special needs. They do not stand stll very much. It will be challenging.
Andrew Skinner
Thank your for the usefull tips
Neven
sluggy_warrior Veteran Member • Posts: 3,204
Re: X100 group shot
And shoot RAW+JPG. As long as there's no significant clipping, most harshness due to high DR can be compressed/resolved with RAW.
Besides, you can't be sure if the camera will get the correct WB, skin tone might be slightly off. Having the RAW will save the day.
Yes! I had f/5.6 or f/6.4 for 4 rows
Yes. Take a lot to be on the safe side. If people don't move too much in between shots, it's relatively easy to use Hugin with masks to merge the eyes/faces from multiple shots.
An example: the stage light wasn't even, very bright in the middle while it's relative dark around, the RAW was much easier to process than JPG.
SOOC preview extracted from RAF
from RAF processed in darktable
Re: X100 group shot
Very nice. In this particulary photo where exactly is your focus point?
Neven
Re: X100 group shot
I think it was the girl with pink wig/hair in the middle.
My reasoning was: even if I don't have enough DoF, the faces in front row are of slightly larger sizes, there should be enough details even if they're not in focus. The people in the back have smaller faces, so they should have more focus/sharpness.
I was shooting from slightly higher than the stage, trying to have the focal plane parallel to the front-to-back plane (the plane of all faces).
Another advantage of the RAF is the flexible sharpening. I ran the export through RL-deconvolution (50 iterations), which is very good at deblurring, but it's an intensive process not meant for in-camera processing.
https://gmic.eu/reference/deblur_richardsonlucy.html
Also, depending on the lens, you'll need to balance between resolution vs corner/edge sharpness. If I shoot with the 18-55 for example, I'd not frame people too close to the edges because of distortion and softness, thus people would have smaller faces (in terms of pixels). For this shot, the 50-140 is excellent across the frame so I was able to zoom in tightly to maximize the pixel count.
