Is the Fujinon XC 50-230mm compatible with a Fujifilm X100V?
ChrisO96 New Member • Posts: 1
Hello,
I recently bought an X100V and got the XC 50-230mm with it as a gift! I am wondering if this lens can be used with the X100V? Is there any way that it can be used with the camera or not really?
Thank you for your help and look forward to hearing from you!
Fujifilm FinePix X100 Fujifilm X10 Leica X1
biza43 Forum Pro • Posts: 15,074
Re: Is the Fujinon XC 50-230mm compatible with a Fujifilm X100V?
No. you can not change lenses in the X100.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
LeicaC Regular Member • Posts: 331
While the x100v is a fixed-lens camera rather than an interchangeable lens camera, you can purchase screw-on add-on lenses. The wide converter yields a 28mm view (versus the camera’s native 35mm-equivalent focal length), while the tele converter yields a 50mm-equivalent focal length. I use the wide converter much more than the tele converter as the latter is more bulky, but it would be useful for someone that really likes doing head and shoulders portraits.
the x100v also has some digital tele settings that simulate a longer lens quite well (50mm and 70mm with the native lens; 72mm and 100mm with the tele converter lens attached), these work better than I expected and are simpler than having to crop the image later. Historically you had to be shooting JPEG-only to use this feature, but now it works with RAW shooting, as well.
If you want to use all the regular XF and XC lenses, you will need one of the Fuji X interchangeable lens bodies:
https://fujifilm-x.com/en-us/products/x-series/#cameras
Craig268
Craig268 Senior Member • Posts: 2,005
ChrisO96 wrote:
Hello,
It's a wonderful lens but as others have noted, the X100V doesn't allow lens changes. The XC 50-230 will however fit on any XT or XH body of which there are many to choose from.
 Craig268's gear list:Craig268's gear list
Fujifilm X-T1 Fujifilm X-T10 Fujifilm X-T4 Samyang 85mm F1.4 Aspherical IF Fujifilm XC 16-50mm F3.5-5.6 OIS +11 more
DarnGoodPhotos Forum Pro • Posts: 11,881
I once held my iPhone camera against binoculars to get a pseudo zoom.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
