RE: K70
TomWret
TomWret Veteran Member • Posts: 4,692
RE: K70
I've been trying to take short (10) sec. photos. It shows in the menu a self-timer lite and Remote Control tite both lites are turned on. Where is the activation button to activate the timer?
Thanks, Tom
Also is there a hand held remote shutter release?
 TomWret's gear list:TomWret's gear list
Epson Stylus Photo R3000 +6 more
Pentax K-70
DavidWright2010 Veteran Member • Posts: 3,737
Re: RE: K70
Thanks, Tom
Yes, there is a remote. I got it on Amazon. It plugs into the mic  port.
You're trying to do a video, right? I did one with this remote and it was very simple. I went into video mode, turned on the remote, chose to use it, and then  the start button started and stopped the video.
David
 DavidWright2010's gear list:DavidWright2010's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD1 Merrill Pentax K-1 +1 more
kypfer Contributing Member • Posts: 985
Re: RE: K70
DavidWright2010 wrote:
Thanks, Tom
Just make sure you get the CS-310 (compatible) release, not the earlier CS-205 … the CS-310 has a 4-pole 3.5mm plug, it's only used with the K-70, KP (and presumably KF).
With the K-70 you also have the option to use an infra-red remote control, but the receiver port is only on the front of the camera … good if you want to be in the picture/video, awkward if you want to be stood behind the camera.
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
TomWret
OP TomWret Veteran Member • Posts: 4,692
Re: RE: K70
Thanks, Kypher that's pretty much what I wanted to know however; what is the part number of the IR one? That one is what interest me the most or maybe both.
Tom W
Ordered this one: https://www.amazon.com/gp/css/order-history?ref_=nav_orders_first
Re: RE: K70
Tom W
Unfortunately that link asks for a login
The Pentax part number is O-RC1 for the Waterproof Remote Control … which are, unfortunately, both expensive and sealed, needing to be returned to a "service centre" to have the battery replaced (I believe it's soldered in!)
There is/was also a Remote Control F that was compatible with the DSLRs … I believe it's been discontinued.
I use similar to IR WIRELESS REMOTE CONTROL for PENTAX K-M K-7 K110D MZ-6 K10D K20D K100D K200D | eBay… somewhat cheaper and the battery is replaceable When my original one failed (bought some 20 years ago with my *ist film camera) I just bought a new one
All Pentax DSLRs that have i/r remote capability use the same unit, so compatibility isn't an issue … I don't know how far back in history this compatibility goes, so couldn't guarantee an i/r remote initially released for a film camera would work with modern units.
