Green and Purple Splotching
furtle
furtle Senior Member • Posts: 1,572
10
I see it was a problem way back.
Best, Steve
 furtle's gear list:furtle's gear list
Ricoh GR Digital III Sigma DP2 Merrill Sigma dp3 Quattro Sigma dp0 Quattro Sigma sd Quattro H +2 more
rick decker
MOD rick decker Forum Pro • Posts: 19,097
Re: Green and Purple Splotching
5
yes back then and even today they love his work...Sigma gets a few blotches and it is like a dreaded disease!!
It is a tough job living in Hawaii but somebody has to do it.
http://www.lightreflection.com
http://www.rickswavepics.com
D Cox Forum Pro • Posts: 32,979
I came across a few cases of green/magenta noise in shadows when reprocessing some NEX-5N photos. It isn't only Foveon sensors.
Probably limited dynamic range is the real problem.
Don
Sigma fp
When Monet was getting going with his career, the obvious brush marks were heavily criticised. Critics found the impressionist technique coarse and clumsy.
The Foveon colour blotches are a defect, not an intentional effect (unlike added film grain). It would be good to see less of them in images from the proposed full frame 3-layer camera.
Don
Sigma fp
Ceistinne
Ceistinne Veteran Member • Posts: 3,256
Don
Don,
If those defects are not eliminated in the expected X3 Full Frame sensor I believe Kazuto Yamaki will not release it to be used in a new camera.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
furtle
OP furtle Senior Member • Posts: 1,572
Don
Same with my Sony A7S.  And a pal is a pro photographer with some serious Canon kit and I noticed some of his pics he posted on Facebook had green/magenta in the shadows.    Best not try to increase the exposure of the shadows and let them be, umm, shadows.
Best, Steve
Don
Or go over the shadows in Photoshop (or similar) with a big soft brush in saturation mode. Or in color mode. Set a low percentage so you can build up gradually.
Don
Sigma fp
sambaba Forum Member • Posts: 85
AI can fix this...
 sambaba's gear list:sambaba's gear list
Sigma DP2 Merrill Fujifilm FinePix S5 Pro Sigma SD1 Merrill Nikon AF Nikkor 50mm f/1.8D Sigma 150mm F2.8 EX DG OS Macro HSM +2 more
