85mm f1.2 L I / 85mm f1.8 v 24-105 f4 L
HappySnapper1 Forum Member • Posts: 85
I’ve got a 24-104 f4L USM which I like a lot, thinking about an 85mm prime for bigger appature for that dreamy wide open portrait shot. But I’m also thinking about more general use. I’d be interested in folks view about image quality at f8/f11 between
EF 85 f1.8 v 24-105 f4 L
EF 85f1.2 L ii v 24-105 f4 L
EF 85 f1.4 L IS USM v the 24-105
i do have an EF 50mm f1.4 that I like but it’s a bit short for portraits.
Kind Regards
Happy Snapper
Kjeld Olesen
Kjeld Olesen Veteran Member • Posts: 4,594
Re: 85mm f1.2 L I / 85mm f1.8 v 24-105 f4 L
I think you will be hard pressed to spot the difference between the zoom and primes at f/8.0 and above, unless you spend all your time pixel peeping at 100% - though I am sure some owners of the f/1.2 and f/1.4 L primes will claim otherwise
Some 100% pixel peeping at the-digital-picture and my own comparison against the f/1.8
 Kjeld Olesen's gear list:Kjeld Olesen's gear list
Canon EOS M Canon EOS 6D Canon EOS M5 Canon EOS R6
OP HappySnapper1 Forum Member • Posts: 85
Kjeld many thanks for that very interesting. Will take look on computer screen later but on phone I’d say the 85/f1.8 has the edge on the 24-105 in terms of sharpness. But as you say that’s at 100% pixel peeping & that’s not generally how we look at the finished (printed) output.
given I’m happy (more than) with the 24-105 I’m thinking I’d not be disappointed with the 85/f1.8 wondering if the 85f1.2L ii or 85f1.4 L IS really offers more…
Kind Regards
Happy Snapper
expro Senior Member • Posts: 2,274
If you shoot f4 or wider then buy the 85s otherwise don’t bother.
They have better contrast and rendering at all apertures  but if you’re not a wide aperture prime type of shooter then it’s a waste of your cash.
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
neilt3
neilt3 Veteran Member • Posts: 3,011
Your thinking of buying an 85mm f/1.2 lens to use at f/8-11 ?
Stick with your zoom lens in that case .
If your looking at shooting wider than f/4 , fine get one . You might want to hire them first and compare all four lenses .
Lenses like the f/1.8 you can buy out of curiosity, and resell if not suited without a great loss .
If you don't know if you need the f/1.2 or f/1.4 , ( used at or near wide open ) then you need to try them first to find if you even have a use for them , preferably side by side .
But if your intending to use them mostly at f/11 , I think your missing the point of them and should stick with your zoom at f/4 .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
tcphoto1
tcphoto1 Senior Member • Posts: 1,408
If you stick to your preference of shooting at F8-11, I'd stay with your zoom. The 85L is notoriously slow focusing in AF mode, the 85/1.8 is a solid performer and the original 24-105/4 is the worst amount them. I've owned all three versions of the 85L and the 85/1.4LIS is my favorite both in images and speed of focusing.
 tcphoto1's gear list:tcphoto1's gear list
Canon EOS 5D Mark IV Canon EF 50mm f/1.2L USM Canon EF 100mm F2.8L Macro IS USM Canon EF 16-35mm F4L IS USM Canon 85mm F1.4L IS USM +10 more
PhotosFlight
PhotosFlight Contributing Member • Posts: 609
The 85 1.8 is a great lens...well ok it is a good lens with some optical flaws under certain conditions, but every time I shoot with it I truly enjoy the results and for about $500 it is an excellent value.
 PhotosFlight's gear list:PhotosFlight's gear list
Canon EOS 30D Canon EOS 50D Canon EOS 7D Mark II Canon 6D Mark II Canon EOS R6 +14 more
Thanks for comments folks.
At the moment I’ve ruled out both the 1.2L lenses due to slow focus. Out of the 1.8 or 1.4 I’m leaning towards the 1.8 I’m thinking that in the real world (not pixel peeping) it will produce images I’ll be happy with.
The reason I asked about performance of the L’s at f8/11 is I do some studio work with the 24-105 Mk1. and whilst I’m happy with results I did wonder if the L primes would be noticeably sharper than the zoom.
Kind Regards
Happy Snapper
Good thought about getting the 1.8 and selling on at modest loss if not liked.
suspect the -.8 will win out.👍
Kind Regards
Happy Snapper
Canon_Guy
Canon_Guy Senior Member • Posts: 1,489
If you plan to use the lens at f/2.2 or slower aperture, the f/1.8 will not disappoint you. At f/1.8 if lacks sharpness and contrast a bit and can produce really ugly amounts of fringing. But you can reduce that by careful choosing of the scene and its light.
For wide opened shooting I'd see the 85/1.4 (Canon or Sigma) as clearly better option.
At f/8-11 there is very small to no difference in sharpnes between 85mm primes and the EF 24-105/4 Mk I.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
