M200, 25fps, America
BrianOdell Forum Member • Posts: 96
The M200 can’t shoot 24fps in 1080p, but can do 25fps, correct? If I want to shoot 25fps, indoors, in North America, can I do this, flicker free?
Thanks!
Pentax Optio M20
Advi
Advi Regular Member • Posts: 456
Re: M200, 25fps, America
Hi Brian.
I don't own a M200, but i guess it allows you to make a video at 24fps.
Search in the menus for NTSC or PAL.
NTSC has 24 fps and PAL has 25 fps.
You can also select to shoot at 30 fps, 50 fps or 60 fps.
Bye
 Advi's gear list:Advi's gear list
Canon EOS M50 Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM
StrugglingforLight Regular Member • Posts: 126
Advi wrote:
Hi Brian.
On my M200 for FHD I only see 30fps and 60fps with NTSC. With PAL and FHD I only see 25fps and 50fps. I don't use this camera for video; maybe I'm just not seeing the setting.
It does say this in the manual:
[4] 23.98fps
Mainly for motion pictures. (23.98 fps) is available when [: Video
system] is set to [For NTSC].
