A decentered Sigma 28mm f1.4. Would you request a repair?
Iyou1 Regular Member • Posts: 111
At f1.4; 1:1 crop at the best and the worst corner.
the best corner
the worst corner
Kjeld Olesen
Kjeld Olesen Veteran Member • Posts: 4,594
I would not
I think the difference you are seeing is so small, that you risk any attempts to improve it will actually result in making it worse.
I would be very satisfied with a lens performing like this in the corners at f/1.4
 Kjeld Olesen's gear list:Kjeld Olesen's gear list
Canon EOS M Canon EOS 6D Canon EOS M5 Canon EOS R6
lighthunter80
lighthunter80 Contributing Member • Posts: 990
Re: A decentered Sigma 28mm f1.4. Would you request a repair?
  1. Was this manual focus or via live view?
  2. Did you focus on the test chart center or on the corners?
  3. Are these crops from one single image or two separate images?
Testing at f1.4 for corner sharpness is tricky. If you use live view and focus on each corner individually and then compare the images you may get consistent sharpness.
I think your results here don't necessarily conclude that your lens is faulty. Besides, the difference is very minor overall.
 lighthunter80's gear list:lighthunter80's gear list
Canon EOS R Canon EF 70-200mm F2.8L IS II USM Sigma 35mm F1.4 DG HSM Art Sigma 50mm F1.4 DG HSM | A Canon EF 16-35mm F4L IS USM
