Shutter application for Sony / canon cameras for focus bracketing?
Interceptor121 Veteran Member • Posts: 8,691
I have been recommended this app to perform focus bracketing it does a lot of other things but my camera already has them
I wonder if anyone here has used it and what are the results
instagram http://instagram.com/interceptor121
My flickr sets http://www.flickr.com/photos/interceptor121/
Youtube channel http://www.youtube.com/interceptor121
Underwater Photo and Video Blog http://interceptor121.com
Deer Photography workshops https://interceptor121.com/2021/09/26/2021-22-deer-photography-workshops-in-woburn/
If you want to get in touch don't send me a PM rather contact me directly at my website/social media
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
Lothman Senior Member • Posts: 1,149
it works :-)
I tested it some weeks ago but then it was unusable for macro bracketing because it allowed only a too small number of frames. I got a refund and came in contact with Grzegorz the developper of the App. After some conversation he managed to implement a bracketing similar to the old b8stack. You can set Start and End position and a step width is fine enough for 1:1 at open apertures.
This stack was done withe the Sony A7Riv, Sigma 105mm Macro at F4.5, stacked with Zerene pmax more than 100 frames.
best regards
Lothar
stacked
and here at f22
at the small size it seems that stacking could be avoided but a 100% crop comparison shows the much more crisp result of the stack
crops compared
OP Interceptor121 Veteran Member • Posts: 8,691
Re: it works :-)
best regards
Lothar
stacked
and here at f22
crops compared
Thank you so you can actually set the focus motor step in the app
This is interesting
Have you tried the sony imaging applicaiton on the computer? I see no trace of steps but have not rigged it yet
Re: it works :-)
This is interesting
I do not know what you mean with "sony imaging applicaiton". I captured all the single frames, camera was controlled via the App and the finale stacking was done by a software called zerene.
stacker [Zerene Stacker] (zerenesystems.com)
Re: it works :-)
This is interesting
There is a windows and mac program to download called imaging edge desktop that could be used for the same purpose assuming it can control focus steps
Re: it works :-)
yes that is b8stack what I mentioned in my first reply, but as far as I remember the camera has be connected via usb. The shutter app can be used more flexible.
GitHub - binarycamera/b8stack: Focus stacking application for Sony A7 cameras
Re: it works :-)
Excellent thank you very much
out of curiosity what macro lenses do you use?
Re: it works :-)
with AF the Sigma 105/2.8
with a motorised slider and without  AF the Laowa 90/2.8 up to 2:1 and the Laowa 2,5-5x.
For higher magnification I use Mitutoyo microscope lenses.
a sewing needle:
Re: it works :-)
a sewing needle:
Thank you. I have the Sony 90mm which has a lot of focus breathing I think I will struggle with stacking
Re: it works :-)
not when you use specialised software like Zerene
I think you can't avoid "breathing" in macro work because you change the magnification when you focus from let's say 20 to 25cm. So your stacking software has to align and resize all the individual frames. What works very well. I don't know whether Photoshop can do such things.
3D Gunner Senior Member • Posts: 1,025
Re: it works :-)
Can.
Re: it works :-)
It depends how deep you go. The sigma is 75mm at 1:1 the 90mm is 45mm is shrinks much more
Photoshop will align but not resize if I recall correctly other software for sure will do better
Re: it works :-)
3D Gunner wrote:
Can.
It gives weird artefacts when a lens has lots of focus breathing
Re: it works :-)
Photoshop can remove focus breathing with auto-align, and generally offers the possibility to make any necessary correction manually.
With dedicated software you can get some easier results, but in PS you can do anything, if you know how to do it. It is an extremely powerful tool.
Re: it works :-)
Not really
The only way to do it perfectly in photoshop is to align and stretch manually
photoshop is ok for basic stacks of say 16 images with small steps afterwards it starts going off if the lens goes off too much
Auto align just choose between a few of the methods you can choose manually
Re: it works :-)
I have stacked images in all sorts of combinations, from 2-3 frames to hundreds of frames. PS is doing great.
Re: it works :-)
Excellent am glad it works for you
LesPickstock Contributing Member • Posts: 576
Re: Shutter application for Sony / canon cameras for focus bracketing?
What is the app? I cannot see a link/name.
LesP
Dave981 Junior Member • Posts: 46
I think it's the app called "shutter" which isn't a great name for google.  try shutter.dev for the site. my camera isn't supported for stacking so I haven't actually tried it out.
 Dave981's gear list:Dave981's gear list
Sony a6000 Sony a6400 Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS Sony FE 90mm F2.8 macro +2 more
You need to search on app store or google play
