EZGritz
Re: Try This Focus Trick On Your OM-1
We know each other. I've done this with him before. I can shoot right next to him, follow him from corner to corner. I'll be meeting him there.
The difference between us is he does this every week. He knows the locations, angles, car speeds. He knows when to fire the shutter. I don't. I can take 4,000 photos but I don't want to. The last time we did this he zoomed closer in than I did. That's a matter of experience. I'm not sure I can do this as well as he does. I'll try. Other than that this will be a fair equipment test because we will be standing near each other.
This is imperfect. I don't know my camera yet. It will be the second time I used it. I'll have to use AF pretty much out of the box because I don't know any better except that I'll use auto subject recognition and CAF. I hope the camera will find helmets and faces through the glass and capture them as well as the R5 does and the images will be as clear and noise free. I don't expect the backgrounds to be as nice because the 40-150 f/2.8 is notorious for making ugly backgrounds. That's a lens problem, not a system problem. The DoF will be two stops different. This should show how much of a delta there is in a real-world shoot. These are the things I'm looking to compare:
* Will the OM-1 capture helmets and faces - the biggest and most important difference I saw using an EM5.3 and the 14-150
* Will the images be as clean and noise-free in low light
* Will the subject separation be similar or a lot different
If year to all three I'll have to conclude the OM-1 is as good as the R5 for this use case. That's what I want to know. I think shooting side by side and comparing the images on the same computer is the best way to know. Random photos is not. - A few out of each camera does not produce an accurate conclusion because distance to the subject and the background and lighting can be vastly different and can skew the results. I expect the school photographer to make better photos overall because of his experience but a few of the same car, in the same location at the same time viewed on the same monitor should be able to answer my questions. That's the theory. I'm more interested in how they compare in the field in a real-world photoshoot outdoors in relatively low light. The forecast is rain and a temperature range for 40-50. there will be lots of mud, muddy water, and small rocks thrown up in the air. Perfect!
