Shutter time
Started 4 months ago | Questions
Janvdk New Member • Posts: 1
Shutter time
Hello.
I have a canon 500D and I'm looking for a faster shutter time.
When I use the internal flash it will not go faster then 200ms.(with manual mode as well).
Without it I can go to whatever I need but as soon I pop-up the flash it goes back to 200 max
Is there no option the use the flash ???
Canon EOS 500D (EOS Rebel T1i / EOS Kiss X3)
AnthonyL Veteran Member • Posts: 3,686
Re: Shutter time
Read up on Flash Sync speed and it should then make sense to you, eg:
https://www.scantips.com/lights/flashbasics2c.html
 AnthonyL's gear list:AnthonyL's gear list
Canon EOS 700D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +5 more
stevet1 Senior Member • Posts: 1,300
Re: Shutter time
Janvdk wrote:
Hello.
Janvdk,
I am not an expert, but this is how I understand it:
While the flash is capable of firing at speeds of like 1/4000, the camera can't sync with it at any speeds faster than 1/200.
You can use other light sources for a "fill-in" flash, or not use flash at all and let your ISO go higher.
Here's an article about setting the ISO on your 500D:
https://my.canon/en/support/8200495300
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
