Do all macro lenses loose light at close focusing distances?
Ernie Misner
Ernie Misner Veteran Member • Posts: 9,506
Do all macro lenses change effective aperture when focusing extremely close?  Just curious because my Tamron and Nikon macro lenses all did that, but a friend says his Canon macro lenses did not exhibit that behavior.  Thanks for your input.
Ernie Misner
http://www.flickr.com/photos/erniemisner/
Light pollution does not only erase our view of the stars. Scientific evidence suggests that artificial light at night has negative and deadly effects on wildlife, including amphibians, birds, insects, and mammals. ~ Bin Chen
 Ernie Misner's gear list:Ernie Misner's gear list
Nikon Z6 Nikon Z7 II Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm F1.4G Nikon AF-S Nikkor 70-200mm F4G ED VR +5 more
grsnovi Veteran Member • Posts: 3,030
Re: Do all macro lenses loose light at close focusing distances?
Some focus wide open then stop down to take the shot.
Others focus at the set aperture (for example the Laowa 25mm which doesn't "talk" to the camera at all).
Of course, the closer you have to be to your subject, the less light is going to illuminate the subject hence the need for elaborate lighting set-ups in the studio and flash w/diffusers in the field.
 grsnovi's gear list:grsnovi's gear list
Panasonic Lumix DMC-GX85 Sony SLT-A65 Sony a7R III Panasonic Lumix DC-GX9 OM-1 +11 more
Sasquatchian Regular Member • Posts: 248
The short answer, of course, is YES. But here's the reason. As you focus closer you have effectively changed the focal length of your lens (it's only its rated focal length at infinity) but the actual physical size of the aperture remains the same, and since the aperture number is only a ratio between the focal length and the actual diameter of the aperture opening, that f/number changes. f= focal length divided by the diameter of the opening.
So to further elaborate, on a 100mm lens f=100. f/4 equals 100 divided by 4 or a 25mm opening. Extend that lens closer to focus closer, say to 200mm, then f equals 200mm divided by that same aperture opening of 25mm and you now have f/8. So even though the numbers on the outside of the lens have stayed the same, the actual numerical aperture is not two stops less than the markings on the lens.
To give you a rough rule of thumb, a 1:1 macro reproduction ratio loses two f/stops from the marked aperture number. A marked f/5.6 is in fact f/11 even though it still says f/5.6.
When you move even closer you lose more light. At a 2:1 ratio or double life size, you lose another stop of light so that your marked f/5.6 is really now f/16.
Now you can start to see the implications of stopping the lens down too far when doing macro photography, as you'll start to see significant image degradation due to diffraction when you go much past an effective f/11.
Your friend who claims that this doesn't happen on his lens is wrong but you might not want to tell him that in order to avoid a pointless argument. Good enough to know it for yourself and to know it's just simple physics that no one can change or alter.
 Sasquatchian's gear list:Sasquatchian's gear list
Fujifilm GFX 100
Ernie Misner
OP Ernie Misner Veteran Member • Posts: 9,506
Thank you for the technical reasons for the loss of light at high magnification.  Definitely not to be confused with creating more of a shadow on the subject as you move in closer to the subject.  Do normal (non macro lenses) actually not get any darker at their minimum focusing distance?
Ernie Misner
Ernie Misner
Indeed, we do cast a shadow upon the subject by moving in closer - not to be confused with my question about macro lenses however.  Thanks for your reply.  I bet that Laowa 25mm doesn't give much working distance.
Ernie Misner
Technically they do but usually it's not enough to notice or have a visible effect. And to add to what I wrote, if you happen to be using aperture preferred auto exposure, you would get an automatic compensation for any kind of lens. I remember shooting with the Nikkor 105 Micro on my (now) old Nikon F4s with the Nikon Databack on it and that databack would read out the actual compensated aperture as you focuses the macro down to 1:1, which was kinda cool. And if you're shooting digital, you're going to see the image on the back of the camera or on a tethered computer anyway and be able to compensate. I can see a slight change in exposure when doing massive focus stacking from front to back.
Fujifilm GFX 100
Ernie Misner
Thanks for the follow up information.  That is a fun read about using the Nikon Databack on an F4s.  I think auto ISO would be a good way to compensate as well.   Do you use PS or dedicated focus stacking software like Helicon Focus?  I have not done any focus stacking yet.
Ernie Misner
Personally I never use Auto ISO - ever. It introduces unwanted variables into the mix like the possibility of some frames having more noise and less dynamic range, neither of which I want hanging around. I never use Ps for stacking. Well, I did in the very early days when there was no stacking software and I was only stacking two or three images. I would use Free Transform and layer masks and it worked when there were only a couple of images but there was not even Align Layers so that part had to be done manually too.
I use both Helicon Focus and Zerene Stacker and by default use Helicon first and only go to Zerene when Helicon is choking, which is not often. There have been a couple of times where neither worked and I've blended everything manually with Layer Masks. The one part of Ps that does work is Align Layers, so you can run that and then put layer masks on each layer filled with black and then gradually paint in the areas of focus. It's a pain to do it but it is possible when all else fails.
Fujifilm GFX 100
Ernie Misner
Excellent information, thank you. I need to get Helicon Focus. Do you ever use Auto Layer Blend in PS? I have not but did see it mentioned somewhere.
Is PS good for stacking 20 night sky images for noise reduction?  Would Helicon Focus even work for that?
Ernie Misner
fzrTom Senior Member • Posts: 2,333
Yes, it's physical (or optical).
in few words :
- the focal length of the lens is given for a point at infinity, so ray of light coming form the subjet are parallel
- when you get closer to the lens the rays of light are no longer parallel
- the effect of this is that the focus of the lens is thrown back: and thereby the focal length increases
- as the diameter remains constant, the real F/D increases
Franck
 fzrTom's gear list:fzrTom's gear list
Sony a7S Sony a7R III Sony FE 90mm F2.8 macro Sony FE 200-600 F5.6-6.3 Tamron 70-180mm F2.8 Di III VXD +4 more
Ernie Misner
in few words :
Very well stated and thanks for your reply!
Ernie Misner
